Robitronic 1/10 Mini SCUD EP Chassis
1 post in this topic
Mini SCUD EP Series: Cool combination of high performance and racing fun.
1/10 Mini EP Series is a combination of high performance and racing fun. With its narrow chassis design, low CG Motor, battery layout and with a powerful 540 Motor provides maximum handling enjoyment an track.
Features:
Belt drive 4WD
Narrow chassis design
Front / rear bevel gear type diff
Adjustable front up stop/down stop
Adjustable rear down stop
Adjustable steering ackerman
Amuminium cap oil damper
Wheel and tire size is the same as 1/10 M
Front universal swing shaft
All ball ends are stainless steel
New design body mount is suitable for all 1/10 MINI Bodies on the market
12mm wheel adapter and M4 wheel axle fits 1/10 M Rims
N5-Hatchback
Item number: JR0246 Clear Body and decals
CHEV-Pickup
Item number: JR0245 Clear Body and decals
MINI-Pickup
Item number: JR0244 Clear Body and decals
Data:
Wheelbase: 208mm
Width (F/R): 164mm
Tire: 55x25mm (1/10 M)
Gear Ratio: 4:1
Motor: 540
Weight: 960g
Includes:
Factory assembled Chassis
ESC
Li-Po 7,4V, 2600mAh Battery
Steering Digital Servo (ESH9901)
Clear Body (without cutting)
