olly986
VDS Pieces Schumacher 80/90 neuves
73 posts in this topic
Pieces pour Topcat, Bosscat, Cat, Cougar etc...
Grosse liste de produits neufs sous emballages.
Je mettrais des listes a jour regulierement si il y a un interet sinon contacter moi par MP avec une reference.
Premiere liste roues et pneus
Ref Description Qty Prix
T650T CAT REAR TYRES 4*20 SOFT SPIKE PR 7 9,50
T652V CAT FRONT TYRES 3*20 SOFT SPIKR PR 6 9,50
T692J CAT REAR TYRES 6*20 BLOCK BLUE 2 8,50
T698P RIB FRONT BLUE 3 6,50
U1614X FRONT WHEEL 3 SPOKE CAT 2000 1 4,20
U1616Z FR WHEEL 3 SPOKE COUGAR 2000 7 4,20
U224G FRONT WHEEL SPOKED WHITE 1 3,00
U6515J CAT FR 8*20 MINI SP GREEN 2.2 4 8,95
U6517L CAT FR 8*20 MINI SP BLUE 2.2 8 6,50
U6527V CAT RR 8*20 SPIKE BLUE 2.2 4 8,50
U6528W CAT RR 8*10 SPIKE GREEN 2.2 2 8,50
U6532A CAT RR 8*10 CUT SP GREEN 2.2 2 8,50
U6536E CAT RR 22*34 MICROSPIKE GREEN 2.2 2 8,50
U6538G CAT FR 14*34 MICROSPIKE GREEN 2.2 4 6,50
U6544M CAT RR 6*20 SPIKE BLUE 2.2 4 9,50
U6545N CAT RR 6*20 SPIKE GREEN 2.2 2 9,50
U6547P SLIM FR STAGGER RIB BLUE 1 8,95
U6585B RT3 CONTROL FR GREEN 1 8,95
U6630U SST RALLY 25 - WHITE 4 7,50
T685C FR TYRE CAT SPIKE BLUE 1 8,50
U1932Y SST 5 SPOKE 25MM WHITE WHEELS 4 6,50
U2032L SST 5 SPOKE 25MM GOLD WHEELS 4 7,50
U1935C SST 5 SPOKE 25MM SILVER WHEELS 1 6,50
U6628S GREY TYRE INSERTS SST 1 1,50
U6626Q TYRE INSERT SST 1 1,50
U6671T SST MINI PIN 20 YELLOW 3 7,50
U6626Q SST FOAM INSERT 25 SOFT 1 1,50
U6627R SST FOAM INSERT 25 HARD 2 1,50
U6635A SST INSERTS 20MM HARD 2 1,50
U6670R SST MINI PIN 20MM YELLOW 6 7,50
Le premier numero est la quantite en stock le second le prix en Euro, 5% reduction sur 50 Euro d'achat inclu fdp.
Edited by olly986
ajout
Someone sent me a message from Finland but it disappeared from my messages, could you please contact me again on PM rather than the other way you did.
I was able to read your message once but it is gone and I did not take your details etc...
Thank you
Olivier
Deuxieme liste
U1139P FRONT MED SHOCK VARI MOUNT-C2 4 € 3,50
U1247U WING MOUNT O RINGS COUGAR 2 1 € 1,78
U1283E FRONT BUMPER - BOSSCAT 1 € 7,20
U1308D CASTOR BLOCKS - 5,-10 DEG - 2WD 2 PR 1 € 5,50
U1310F VARI SHOCK MLDS- NEW PISTONS 1 € 4,63
U1353W LONG SPRING TUNING SET-COLOUR 2 € 7,50
U1358B PRO SHOCK ABSORBERS-LONG 1 € 28,00
U1360D PRO SHOCK BODY MEDIUM 1 € 6,00
U1361E PRO SHOCK BODY LONG 1 € 5,50
U1362F PRO SHOCK SEAL PACK 2 € 3,62
U1380X WHITE SPRING MEDIUM 1 € 1,95
U1383A GREY SHOCK SPRING - LONG 1 € 1,95
U1386D GREY SHOCK SPRING - MED 2 € 1,95
U1390H GREY SHOCK SPRING - SHORT 1 € 1,95
U1408Z HEX REAR WHEEL DRIVE C2000 PR 2 € 5,85
U1409A WHEEL NUTS C2000 4 SETS 2 € 2,86
U1410B BALL BEARING 10 * 15 * 4 PR 3 € 14,85
U1412D IDLER SHAFT C2000 1 € 2,75
U1415G DIFF WASHER - 18MM C2000 2 € 4,44
U1419K BALL BEARING 4 * 8 *2MM PR 4 € 8,25
U1420L DIFF BALLS - 4MM PK 10 2 € 3,36
U1421M TRANS HOUSING SET C2000 1 € 7,95
U1422N DIFF GEAR C2000 2 € 5,65
U1423O IDLER GEAR C2000 3 € 4,20
U1428T TURNBUCKLE - 60MM 2 € 2,86
U1429U TURNBUCKLE - 53MM 4 € 3,24
Edited by olly986
MISE A JOUR
Troisieme liste
U1433Y REAR WISHBONES C2000 PR 1 € 6,90
U1436B REAR SHOCK MOUNT C2000 2 € 5,50
U1437C REAR PIVOT STRAPS C2000 1 € 3,90
U1438D REAR BULKHEAD MOULDINGS C2000 1 € 6,95
U1439E BALL BEARING 5 * 9 *3 PR 2 € 9,02
U1441G FRONT AXLE C2000 PR 1 € 4,15
U1445K STR POSTS & WASHERS C2000 2 € 6,92
U1447M AXLE BLOCK YOKE & INSERTS C2000 3 € 5,60
U1448N CASTER INSERTS C2000 3 PR 2 € 3,50
U1449O STEERING LEVERS C2000 PR 1 € 5,85
U1453S FRONT WISHBONES C2000 PR 2 € 6,50
U1454T FRONT SHOCK MOUNT C2000 3 € 5,40
U1456V FR & RR BUMPER C2000 1 € 7,05
U1457W FRONT WHEEL 2.1 C2000 3 € 5,60
U1459Y GEAR COVER & BUNG C2000 2 € 5,50
U1477Q FRONT WISHBONES CAT 2000 3 € 7,20
U1478R STEERING YOKES CAT 2000 1 € 5,85
U1479S FRONT HUB CARRIERS CAT 2000 1 € 7,45
U1480T FR & RR BULKHEADS CAT 2000 1 € 7,20
U1481U FR PIVOTS BLKS CAT 2000 3 € 5,65
U1482V FR SHOCK MOUNT CAT 2000 2 € 5,75
U1483W FRONT SHOCK BRACE CAT 2000 1 € 6,90
U1484X FRONT PIVOT BAR CAT 2000 3 € 4,30
U1485Y CENTRE TRACK ROD CAT 2000 1 € 5,65
U1486Z PIVOT SET FR HUB CARR CAT 2000 2 € 4,30
U1487A REAR WISHBONES CAT 2000 2 € 7,20
U1488B REAR SHOCK MOUNT CAT 2000 1 € 5,75
U1489C REAR PIVOT BRACES CAT 2000 2 € 4,20
U1490D PIVOT PIN RR INNER CAT 2000 3 € 4,63
U1491E FR DRIVE BELT CAT 2000 2 € 7,20
U1496J MOTOR SCREW SET CAT 2000 2 € 2,45
U1497K LAYSHAFT CAT 2000 1 € 5,65
U1498L ONE WAY PULLEY SET CAT 2000 1 € 6,92
U1500N FRONT TRANS HOUSING CAT 2000 2 € 8,20
U1504R WASHER CARRIER CO-AX C2000 1 € 9,75
U1505S WASHER CARRIER CO-AX C2000 2 € 9,75
U1509W FRONT AXLE CO - AX U/J CAT2000 2 € 6,67
U1516D FRONT WHEEL 2.2 CAT2000 3 € 5,60
U1534V DUAL RATE SHOCK PISTONS 6 € 7,20
U1536X CO-AX D/SHAFTS CONV - C2000 1 € 36,00
U1607Q ALLOY IDLER GEAR - C2000/2WD 2 € 14,45
U1619C SACS ACTIVE CASTER SET C2000 1 € 19,50
U1620D SWEPT FR WISHBONES C2000 2 € 7,45
U162A DIAPHRAGM - SHOCK ABSORBER PK2 10 € 1,25
Edited by olly986
Quatrieme liste
U1693Z SACS STEERING BLOCKS 1 € 6,95
U1694A XPC CHASSIS LOWER C2000 1 € 16,50
U1695B XPS CHASSIS UPPER C2000 1 € 9,20
U1713T SWEPT FR WISHBONES SACS - 2 1 € 7,20
U1715T FRONT AXLES SACS - 2 2 € 5,85
U1716W STEERING BLOCKS SACS - 2 3 € 4,40
U1717X PIVOT BLOCKS SACS - 2 4 € 3,90
U1725F FRONT WHEEL 3SP CLUB 10 1 € 4,60
U1727H HYDRODRIVE LAYSHAFT SET C2000 1 € 8,50
U1728I REAR SHOCK MNT C2000/95 1 € 6,95
U1738S SPEED PACK - GRUB/SET SCREWS 5 € 2,10
U178P TRANSMISSION HOUSING - 2WD 1 € 4,50
U1796Y REAR HUB CARRIER 1 DEG TOE IN 3 € 6,50
U1797Z RR HUB CARRIERS 2 DEGS 2 € 7,60
U1798A REAR HUB CARRIERS 3 DEGS 2 € 7,35
U1800C RR WISHBONES LAYDOWN CAT 2000 2 € 9,20
U1801D FR WISHBONES CAT 2000 EC 4 € 7,75
U1807J ALLOY RR PIVOT BRACES CAT 2000 EC 1 € 8,70
U1811N REAR SHOCK TOWER WFE COUGAR 95T 1 € 9,20
U1816S REAR WISHBONES COUGAR 95 TEAM 2 € 6,90
U1826C SERVICE KIT VISCOUS DRIVE 2 € 5,50
U1841R 3 DEG REAR BLOCKS/BRACES - CAT EC 1 € 41,20
U1865P RED SHOCK SPRING MED 2 € 1,95
Edited by olly986
Cinquieme liste
U1887V DIFF SCREW SET - BLADES 3 € 5,33
U1912A LAYSHAFT ONE WAY SLIPPER 2 € 6,98
U1916E STEEL D/S BLADES CAT FR 1 € 35,00
U1918G SPARE BLADES PK 4 4 € 7,30
U1957Y BEARING GREESE - BLACK MOLY 1 € 2,67
U195G HI TORQUE DRIVE BELTS 2WD 8MM 1 € 7,70
U196H 21T TOP PULLY 2WD 2 € 2,95
U1987H PIVOT PIN BLOCKS 0+3DEGS F/BL 2 € 5,20
U1993P IDLER GEAR & SIDE FENCES F/B 2 € 6,00
U2033M PLASTIC BLADE DRIVESHAFT - SST 2 € 9,71
U2088D REAR WISHBONES FIR. -USA 2 € 9,85
U2101U A.B.S. SYSTEM - SST 1 € 52,90
U215A GEAR COVER 2WD 1 € 4,50
U227J LAYSHAFT 2WD 1 € 3,62
U229L 95T WHISPER GEAR 48DP 2 € 3,62
U232O 86T WHISPER GEAR 48DP 1 € 3,62
U233P 19T PINION 48DP 2 € 4,95
U235R 25T PINION 48DP 2 € 5,65
U236S 28T PINION 48DP 3 € 5,65
U253J SERVO MOUNTS PR 1 € 3,95
U255L MOTOR GUARD 2WD 1 € 4,50
U322E LOWER FRONT SUSP.PLATE 2WD 1 € 4,80
U324G 95T Q.C. SLIPPER GEAR 48DP 3 € 3,62
U326I 89T Q.C. SLIPPER GEAR 48DP 1 € 3,62
U327J 86T Q.C. SLIPPER GEAR 48DP 2 € 3,62
U373D REAR BODY MOUNT BRACKET 2 & 4WD 1 € 2,60
U5037N UNDERTRAY CAT 2000 1 € 10,50
U5045V BODYSHELL COUGAR 2000/95 1 € 10,50
U637H SHOCK ABSORBER PISTONS (SET 6) SET 4 1 € 1,20
U6500U ROAD & TRACK TYRE RT1 FRONT PR 1 € 7,50
Edited by olly986
sixieme liste
U730D TRUST RACE 1/8*5/16 1 € 7,43
U743Q Q.C. SADDLE PACK TRAY & STRAP 3 € 7,17
U749W STEERING PIVOT SET 2WD 1 € 4,50
U768P REAR SPRINGTUNING SET 1 € 7,45
U776X TOP BKT,YOKES.C.TR.ROD 2WD 2 € 6,00
U796R TURNBUCKLE ADJUSTER 24MM 2 € 2,50
U799U PIVOT BLOCKS OLD TYPE 3 € 4,32
U815K TWIN BEARING MOD 2WD FRONT 1 € 22,50
U816L TUNSTEN CARBITE DIF BALLS 3MM PK 14 1 € 14,50
U843M CERAMIC DIFF BALLS DIA 3MM PACK 14 1 € 19,50
U847Q FRONT WISHBONES (PEP) COUGAR 2 1 € 8,95
U849S 23MM DIFF S11+ECC BGR HOUSING 2WD 1 € 3,50
U850T 23MM DIFF PLAIN BEARINGS 2 € 3,00
U852V STEERING LEVERS (PEP) - 2WD PR 2 € 3,50
U1431W REAR HUB CARRIERS & INSERTS C2000 1 € 5,50
U356V RR SUSP TOP LINK 4WD 1 € 3,50
U1922L BLACK SHOCK SPRING TR6 RATE 6 1 € 2,50
U2238G REAR BELT 125*4MM SST 1 € 9,46
U2323G FR BUMPER SST 1 € 7,15
U1919H ANTI ROLL BAR SST 1 € 7,17
U294C REAR WISHBONES SHORT 2 € 3,50
U2166W ALLOY BLOCK & ADJUSTERS BODY POSTS 3 € 10,50
U2392N C/F NICAD X BLACK AXIS 2 1 € 22,00
U900K VARI SHOCK MOULDINGS 2 € 4,50
U2201M FRONT WISHBONE 15DEG SACS 1 € 4,50
U2228V FRONT SHOCK MOUNT EVO2 1 € 9,10
Septieme
U1541C SPEED PACK MED M3 PAN HD 2 € 1,40
U1542D SPEED PACK LONG M3 PAN HD 2 € 1,40
U1546H SPEED PACK - LONG M3 CAP HD 4 € 1,40
U1547I SPEED PACK - M3 NUTS 2 € 1,40
U1550L SPEED PACK SOCKETS WRENCHES 1 € 1,40
U1876G HUB CARRIER - SST 8 € 7,55
U1877H HI - TENSILE PIVOT BALL SST 2 € 3,24
U1882N FR UPPER WISHBONES SST 2 € 9,46
U1883P RR UPPER WISHBONES SST 2 € 12,50
U1884R LOWER WISHBONES RR SST 2 € 9,46
U1886U HEX WHEEL DRIVE SST 2 € 8,20
Edited by olly986
mise a jour
Septieme et derniere liste
U1537Y SPEED PACK SHORT SELF TAP PAN 3 € 1,10
U1538Z SPEED PACK LONG SELF TAP PAN 1 € 1,40
U1539A SPEED PACK SELF TAP CSK HD 1 € 1,40
U1541C SPEED PACK MED M3 PAN HD 3 € 1,40
U1542D SPEED PACK LONG M3 PAN HD 3 € 1,40
U1544F SPEED PACK SHORT M3 CAP HD 2 € 1,71
U1545G SPEED PACK MED M3 CAP HD 2 € 1,40
Huitieme
GO30 SILICONE SHOCK OIL 30W 2 € 3,50
G035Y SILICONE SHOCK OIL 35W 1 € 3,50
G080C SILICONE SHOCK OIL 80W 2 € 3,50
G961F MOTOR CAPACITORS PK 3 4 € 2,20
GM1230 GOLD PLUGS 4PCS MALE 3 € 5,25
GM1271 BATTERY DISCHARGE KIT 2 € 4,20
GM1280 BATTERY BARS COPPER 1 € 7,50
GM9713 S.FALTA MODIFIED 3 * 11 1 € 65,00
GMMB03 GM RACING BRUSH 20/30 RUN 3 € 4,20
U1017X RECOIL SPRING S15R PULL START 3 € 4,50
U1040U CORD - PULL START NITRO 1 € 2,00
U1067V FUEL FILTER PK 3 1 € 1,20
U1097Z HEX DIFF WASHERS 3 € 2,95
U1110M S15R SPRING - SILENCER 1 € 1,10
U1115R S15R NEEDLE 1 € 5,50
U1116S S15R GASKETS,O RINGS & WASHERS 2 € 7,50
U1118V S15R COMPETITION GLO PLUG 2 € 4,50
U1129F PIVOT BLOCK 1/8 REAR W/D 2WD 1 € 3.50
U1134K REAR WISHBONE-LONG W/B-1/8 PIN 1 € 5,50
U119J AERIAL TUBE 1 € 1,50
U1202B PISTON ROD, LONG-VARI SHOCK 1 € 4,25
U1297A FRONT HUB CARRIER BOSSCAT 1 € 7,35
U1301W SILICONE DIFF GREASE - TUBE 1 € 2,67
U1342L RESISTOR - CLUB 10 SPEED CONTROL 1 € 2,20
U1417I DIFF SCREW DISC SPRINGS & WASHERS 7 € 3,94
U1418J O RINGS 10*1MM PR 3 € 1,75
U1432X TOE I INSERTS - C2000 2 € 3,50
U1629M 36T DIFF PULLEY NITRO 10 1 € 3,80
U1630N TRILOBE WASHER CARRIER NITRO 10 2 € 2,40
U1632P LAYSHAFT NITRO 10 1 € 4,80
U1634R 15T ALLOY PULLEY - NITRO 10 1 € 4,75
U1635S DISC BRAKE CAM NITRO 10 1 € 8,50
U1636T DISC BRAKE REPAIR SET NITRO 10 1 € 4,75
U1637U DRIVE BELT 55T NITRO 10 2 € 6,50
U1740U SHOCK MT LOSI ACT CASTER 1 € 4,50
U1741V AXLE SCREW & NUT LOSI ACT 1 € 6,20
U7006G SPACER & NUT , CLUTCH/FLY W-SI5R 1 € 10,50
U7007H PULL START - NITRO CPL 1 € 10,50
U701A 2WD PULLEY SET 2 € 6,00
U717Q ADJUSTABLE SERVO LINK 2 € 3,50
U721U OILITE BEARINGS - WHEELS PR 1 € 2,50
U722V O RINGS 1/8 PK OF 10 1 € 2,72
U761I DISC SPRING 1/8 1 € 1,65
GM9678 27*1 PUPLE BULL STOCK MOTOR 3 € 25,00
U1723D LEXON RADIO MOUNTS 1 € 6,50
U2311T 22T PINION 48DP 1 € 4,95
U7004E SEAL FOR FUEL TANK-NITRO 1 € 1,85
G830E HI PEAK CHARGER 1 € 48,00
Pour toutes commande au dessus de 50 euros 5 % reduction
Contacter moi par MP pour confirmation, paiements paypal seulement
Edited by olly986
Bonjour, je suis intéressé par les pièces suivantes :
U1510X rear axle co-ax U/J il m'en faudrait deux
U1406X chassis gate C2000 il m'en faudrait aussi deux
U1586V
U1403U wing & side plate off road
U5045V bodyshell cougar 2000/94
les avez-vous toujours en stock et comment cela se passe-t'il pour l'envoi et le règlement?
Merci d'avance de votre réponse
Guillaume
Salut Guillaume
Je me renseigne sur la dispo, passe en MP apres
Bonjour, cette fois j'ai vraiment besoin rapidement de triangles avant de cat 2000 (U1477Q)
Merci de me donner les délais de livraisons, frais de port et adresse de paiement.
Cordialement
Ps: j'ai écris ici car ta boite de mp est pleine.
Merci de me répondre rapidement c'est urgent.
Il me faudrait également ceci : "U225H REAR WHEEL SPOKED WHITE 1 3,00"
salut tu as un MP, j'ai les pieces, si tu me contact ma boite est prete pour recevoir ta reponse
bonjour vous avez toujours des pièces de cougar 2000.
Hi
I wondered if you still had the following schumacher parts from your list for sale?
U1354X WORKS TRANSM CONVERSION 1 € 22,00
U765M FR ANTI ROLL BAR KIT 4WD 2 € 8,90
U766N REAR ANTI ROLL KIT 4WD 1 € 9,50
U1363G WORKS REAR SUSP CONVERSION 1 € 20,00
If so I would definatly like to buy all 4 items from you let me know your paypal address and how much postage to the uk and I will send the money now
Let me know
Edited by renay
bonjour je cherche
1420l
1918
1422
1607q
1715t
1498l
et aussi des pièces pour mi2ec
c''est toujours dispo,si vous avez des coordonnées pour le règlement
Hi
Tried to pm you but it says your mailbox is full, I would like to order the following parts from you
U224G FRONT WHEEL SPOKED WHITE 2 3,00
I know I have only posted on here twice, but my name on RC10TALK.COM, OOPLE, TAMIYACLUB is CATS and I have traded many times on all those forums I have a 100% postive ebay score
Let me know your paypal plus postage to the uk and I will send the money
Let me know
Scott
Edited by renay
added parts
not sure if your getting my private messages as your mailbox is full, please contact me reference the parts Ive mentioned,
Thanks
Scott
Edited by renay
bonjour je cherche
1420l EN STOCK 3.36€
1918 ??? SANS LETTRE ? JE DOIS DEVINER ?
1422 DE MEME ??
1607q EN STOCK 14.45€
1715t EN STOCK 5.85€
1498l EN STOCK 6.92€
et aussi des pièces pour mi2ec PAS DE PIECES, MON TITRE EST POUR PIECES VINTAGES
TU AS DEJA MES COORDONNEES SUR TON MP, QUAND EST IL POUR LES PIECES DEJA DEMANDEES, LES PRENDS TU OU NON
Je t'ai deja repondu en MP auparavant mais sans reponse de ta part??
Edited by olly986
