Kyosho inferno mp9 tki 2
7 posts in this topic
Overview
In the two years since it made its mark at the 2008 World Championship, the prototype MP9 Kyosho International has forged the cutting edge of performance technology with the latest version 2. Tested and proven at numerous international racing events, design upgrades have evolved multiple areas of the chassis platform to a new level. However perhaps the greatest innovation has been the dramatic reduction in cost, despite the significant upgrades and performance improvements. The chassis design focus is on efficient traction and is realized through short suspension arms and unique rear hubs that produce effective traction with light suspension stroke. Shock absorber design has changed from spacer setting adjustment to dial adjustment and incorporates the previously optional shock pistons with tapered holes that produce optimal piston speed and damping power over long running times. Other features include a new low-height body design with less front-end resistance that generates aerodynamics for a competitive edge and stable posture through the air. With the power of the most advanced racing performance firmly in your grasp, the innovative design of the new TKI 2 puts racing glory within reach.
Available: Mid August 2010
# Instructions
# Exploded View
# Parts List
Features
* New Threaded Big Bore Shocks - Dial adjustable big bore shocks allow precision adjustment of front-rear and left-right suspension.
* New Design MP9 Wheel - New design of the dish wheels is lightweight with optimal rigidity and supports sure traction and effective tire grip.
* New Tapered Shock Pistons - Shock pistons with taper holes deliver optimal oil flow resistance and piston speed for superior damping effectiveness.
* Improved King Pin Design - Longer king pin and longer flanged collar improves reliability and prevents knuckle coming loose in the event of hard contact or a crash.
* Aluminum Wing & Radio Post - Machined aluminum wing stay posts and radio plate posts deliver improved reliability through increased strength and rigidity.
* Machined Rear Sus. Holder - Machined aluminum rear suspension holder delivers increased durability, even under the stress of big jumps.
* New Suspension Bushings - New white suspension bushings are now included provide you high visibility of your setup.
* New Aluminum Rear Hubs - New design of the aluminum rear hubs effectively realizes shorter suspension arms to deliver reactive movement for traction efficiency.
* New Body Design - new low-height body design with less front-end resistance that generates aerodynamics for a competitive edge and stable posture through the air.
* New Air Filter - This high capacity air filter allows a long and consistent air feed to your engine.
Standard Features
* Ultra Low C.O.G - Ultra low center of gravity, lightweight and optimal weight balance all combine to deliver the ultimate racing weapon.
* More Down Force - Bolted on large wing generates powerful down force. New ribbing at the back results in improved rigidity.
* 7075 Grade Aluminum - Hard main chassis made from 7075-grade aluminum, hard shock stay, big bore shocks and aluminum knuckle arms realize great strength, durability and rigidity.
* Hard Anodized Components - The shock stay and main chassis are hard anodized for improve resistance against dirt and damage.
* Composite Torque Rods - Resin torque rods fitted on front and rear contributes to moderate flexibility and smooth running performance.
* Endless Adjustments - Roll center can be adjusted by changing the direction of the spacer inserted into the lower arm of the rear suspension. Also, the one-piece ball and washer ball-ends are an added maintenance feature
* Upright Servo - Servo is mounted upright for easy maintenance and is dropped 2mm to contribute to the lower center of gravity. The hard chrome finish to the metal parts is more resistant to damage and dirt than anodizing.
* Extremely Light Weight - The smaller differential units on front and rear with grooved cup joints, aluminum balls and the flexing shape of resin parts effectively lightens the weight while giving the chassis rigidity, more durability and strength.
* New Fuel Tank - Newly designed fuel tank features finger hook for fast and reliable refueling and realizes stable fuel supply in even under severe posture changes.
* Wraparound Side Guards - Grooved face in side guard matches the thickness of velcro tape and prevents dirt getting inside the chassis. Complete wraparound side guards only found on Kyosho MP9.
* Equipped With Mud Guards - Mud guards on the rear arm prevent dirt entering the drive shaft and getting inside the wheels.
* We Have You Covered - 3 types of servo horn included for various R/C systems (SANWA / KO / for JR, FUTABA and Hitech)
* Hex Screws - Kit includes all hex screws enough said!
* Weight Balance - Engine position moved 15mm forwards and 5mm to the center compared to the MP777. Also the height has been lowered by 1mm for ideal weight balance.
* New Suspension Design - Newly developed suspension uses bushing for easy maintenance and rationalizes the setting order.
* Increased Diff Case Capacity - Center differential realizes improved heat dissipating brake disc and increased case capacity for stable control through to the end of the race.
* Optimal Race Settings - Fine tune for the optimal race setting with adjustments to wheelbase, tread, roll center, caster angle, toe angle and camber change.
* 3 Differentials = Real Time 4WD - Features the Inferno's signature shaft-driven 3-differential full time 4WD chassis.
* What is a KIT? - A KIT is a higher level vehicle that included nearly everything you will need to build a rolling chassis. You will need to supply items like engine, pipe, body, tires, wheels and radio equipment. Required items may vary from kit to kit so please see Required Items For Completion section for full list.
Kit Contents
* Unassembled Kit
* New Clear Body
* New Wheel Set
* Decal Sheet
* Instruction Manual
Required For Operation
* 2-channel, 2-servo R/C System for cars
* 21-class Engine
* Pipe & Header
* Engine starting tools
* Batteries for R/C system
* Tires & Inserts
Description
Introducing the new MP9 TKI 2 Spec A, race roller edition. In the two years since it made its mark at the 2008 World Championship, the prototype MP9 Kyosho International has forged the cutting edge of performance technology with the latest version 2. Tested and proven at numerous international racing events, design upgrades have evolved multiple areas of the chassis platform to a new level. However perhaps the greatest innovation has been the dramatic reduction in cost, despite the significant upgrades and performance improvements. The chassis design focus is on efficient traction and is realized through short suspension arms and unique rear hubs that produce effective traction with light suspension stroke. Shock absorber design has changed from spacer setting adjustment to dial adjustment and incorporates the previously optional shock pistons with tapered holes that produce optimal piston speed and damping power over long running times. Other features include a new low-height body design with less front-end resistance that generates aerodynamics for a competitive edge and stable posture through the air. With the power of the most advanced racing performance firmly in your grasp, the innovative design of the new TKI 2 puts racing glory within reach.
Available: Mid September 2010
Features
New TKI 2 Features
Reliability & Workmanship - After partial assembly by our skilled staff, all Spec A kits are inspected by the Inferno master Yuichi Kanai to guaranty reliability on all kits.
Standard Features
What is a ARR? - A ARR Kit is a higher level semi-assembled vehicle that included nearly everything you will need to get started. You will need to supply items like engine, pipe, body, tires, wheels and radio equipment. Required items may vary from kit to kit so please see Required Items For Completion section for full list.
All made in Japan!
Everything from the ground up is made in Japan for the highest level of quality and reliability.
All Spec A kits are checked by Yuuichi Kanai!
Spec A (ARR) are also referred to as a Race Roller is a semi assembled kit. All Spec A kits are factory assembled by dedicated staff with years of RC experience and thoroughly checked by the designer Yuuichi Kanai himself to deliver the best buggy known to man. Even the small details such as ride height and alignment are strictly measured and set one by one. All this time and care allow you to receive a race ready chassis.
Kit Contents
* Semi-Assembled Kit
* New Clear Body
* New Wheel Set
* Decal Sheet
* 21-class Engine
* Pipe & Header
* Tires & Inserts
INFERNO MP9 TKI 2 WC EDITION
Description
The time has arrived to experience the Inferno’s legendary racing performance. With a total of 8 Off-Road World Championship Victories, the Kyosho Inferno series has established and unrivalled record of success. The machine that was driven to victory by Team Kyosho International driver Cody King is now ready for all 1/8 buggy fans to own. With a revised design of the front and rear suspension holder adds strength so the TKI 2 can take on the hardest courses the world has to offer. Also, the battery position has been re-located to the front for improved balance and control under many different conditions. As the name indicates, you can discover what its like to drive the world’s fastest off-road machine with the Inferno MP9 TKI 2 WC (World Champion) Limited Edition.
Tested and proven at numerous international racing events, design upgrades have evolved multiple areas of the chassis platform to a new level. The chassis design focus is on efficient traction and is realized through short suspension arms and unique rear hubs that produce effective traction with light suspension stroke. Shock absorber design has changed from spacer setting adjustment to dial adjustment and incorporates the previously optional shock pistons with tapered holes that produce optimal piston speed and damping power over long running times. Other features include a new low-height body design with less front-end resistance that generates aerodynamics for a competitive edge and stable posture through the air. With the power of the most advanced racing performance firmly in your grasp, the innovative design of the new TKI 2 puts racing glory within reach.
Available: March 2011
Features
New TKI 2 WC Features
* Machined Sus. Holder – Strengthened front lower suspension holder is wider and thicker giving you the ability to handle big jumps and hard surfaces.
* Heavy Duty – Strengthened front shock tower features a thicker construction giving you the ability to handle what ever your local track can dish out.
* Redesigned Arms – Redesigned and reinforced for extra strength around the stabilizer mounting holes on the front lower suspension arms.
* Increase Strength – Reinforcing ribs on the ball end sections of the rear upper suspension arms dramatically increase strength and rigidity to handle hard contact.
* Move Up – The receiver battery is now positioned further forward to improve jumping control and cornering.
* Rear Shock Stay – The rear shock tower is reinforced in the same way as the front and now featuring 10 upper arm mounting holes for a more precision set up.
Standard Features
* Reliability & Workmanship - After partial assembly by our skilled staff, all Spec A kits are inspected by the Inferno master Yuichi Kanai to guaranty reliability on all kits.
All made in Japan!
Kit Contents
* TKI 2 WC Kit
* New Clear Body
* New Wheel Set
* Decal Sheet
* 21-class Engine
* Pipe & Header
* Tires & Inserts
Technical Data:
* Scale: 1/8
* Length: 490mm (19.2in)
* Width: 307mm (12.0in)
* Height: 180mm (7.0in)
* Wheelbase: 325mm (12.7in)
* Ground Clearance: 28mm (0.8in)
* Gear Ratio: 11.7:1
* Weight: 3,300g
