Short Course Conversion Kit for XXX-T based trucks
9 posts in this topic
Team CRC Short Course Conversion Kit for XXX-T based trucks
Move over you other LCG Short Course Trucks, the dominant Losi XXX-T platform has just entered the SC category as well, (with a little help from Team CRC!). What else can we say about this truck that Team Losi hasn't already proven on the race track over the last decade or so. The truck handles extremely well and has excellent durability too. It's light, nimble, and has always been class leading in chassis, suspension, and tuning feature innovation.
Now you can pull those XXX-T's off the shelf that you sidelined when the Short Course craze started, and convert them into the baddest SC Truck on the track. This set converts most all XXX-T truck kits from Team Losi, including the Desert Truck (pictured here) & XXX-T CR utilizing carbon fiber chassis extensions that allow you to use your stock rear bottom plate. Using the stock rear bottom plate makes converting any XXX-T a breeze because there will be no complications with the rear arm mounts, transmissions, etc not matching up. RTR's, MF 1's, MF 2's, Desert Trucks, and the newest XXX-T CR's can all be converted using this setup. (the CR will require you to replace the quick change hubs and axles over to standard type axles).
The conversion does require you to drill two small 4-40 size holes in the front bulkhead, but this is very easy to do, and a drill bit is even included in the kit so you don't have to track one down. As you can see in the pictures below, the front bulkhead is already pre-marked! All you have to do is drill a hole in the center of each mold mark, and BAM...the front body mount is on.
7700 SC conversion for XXX-T trucks (w/ bumpers) 800734077008
7701 SC conversion for Desert Truck (no bumpers) 800734077015
As you can see in the pic above, you can trim out the plastic backstop in the XXX-T chassis, giving you the most front to back battery adjustment of any SCT. (just don't cut the whole bridge out or you won't have anywhere for your battery strap to attach to).
Meets all ROAR rules for SC truck dimensions. Body and Tires NOT included. Uses SC10 style wheels from any of the popular wheel manufacturers, or you can also add the hex adapters from the Losi Strike and use Strike wheels!
www.teamcrc.com
Now Team Losi owners have something to ‘strike’ fear into their competition! With this upgrade kit you can convert the venerable XXX-T into a completely ROAR legal SC power house. Developed and tested to insure the best performance, fit and durability this superb SC conversion will get you into the winners circle!
LOSI XXX-T (MF, MF2 OR CR) REQUIRED.
SC10 WHEELS, SC10 or STRIKE TYPE BODY, STRIKE FRONT BUMPER and SLASH 4X4 REAR BUMPER ALSO REQUIRED.
COMING MID JUNE 2010!
-Made in the USA of G10 material to match the flex of the XXX-T chassis for unsurpassed traction. 3 different thicknesses are used for the proper strength to flex properties.
-Includes custom made hardened steel front axles that are narrowed for ROAR legal width. Fits perfectly with the XXX-T hubs and SC10 wheels (no press fitting or altering required).
-Unique bumper mounts accepts the Losi Strike front bumper and Traxxas Slash 4x4 rear bumper for extra durability and realism.
-Universal type body mounting for greater body choice and selection.
-Includes polished anodized stand offs and alloy steel hardware (2mm hex wrench required)
-Detailed instructions included.
-Compatible with the Losi Desert Runner or Speed-T if XXX-T front and rear shock and towers are used.
-XXX-T ‘CR’ requires switching the quick change rear hubs and axles with XXX ‘CR’ type hub.
Moi qui ne savais pas quoi faire avec mon XXX-t.....
Hum je sens que mon XXXT MF1 va subir quelques modifications afin de lui redonner une seconde jeunesse, sinon ou peut on truver ces kits les roues qui vont bien et des carro symas?
salut!
J'ai recu mon kit de conversion pendant les vacances et j'ai hate de jouer de la DREMEL!!!!!!
