Speed Passion GT2.1 ProStock
98 posts in this topic
SPEEDPASSION, partner of PETIT RC, sent to us their NEW product
GT V2.1 Pro Stock Edition
The racers asked, and Speed Passion delivers!
Specially designed for tight 12th scale applications, the GT 2.1 Pro Stock ESC is your answer for a small low profile ESC specifically for stock motor racing. The GT 2.1 Pro Stock ESC features the latest top speed and rip enhancing Speed Passion software already preloaded, and uses the same USB update capability as the groundbreaking GT 2.0 so you can always have the latest software advances right at your fingertips. Featuring a tough alloy case and low profile heatsink hard anodized in your choice of shiny blue or serious satin black, the GT 2.1 Pro Stock keeps it’s cool under intense racing loads like no other. Take your stock or spec motor racing to a new level of configurability and performance with the Speed Passion GT 2.1 Pro Stock ESC!
Feature :
- All new Dyanic Multi Timing System - “DMTS2.0”, speical design provide wild range powerfull out put for stock competition.
- Hard anodized aluminum case and integrated heatsink provide excellent thermal efficiency.
- Compact 21mm height specifically designed for 12th scale and mini applications.
- New 30mm high flow fan for even greater cooling and enhanced ESC efficiency.
We are release the new GT2.1 Pro Stock ESC and ready to ship at Feb 10th, 2010 //// Vario prêt à envoyer à partir du 10 FEVRIER 2010
Apparemment ca parle de timing mais dans le détail, aucune idée.
Par contre je suis preneur d'info sup sur le type de moteur, tension mini...
C'est la version utiliser pour le timming variable.
Tous les constructeur s'y met. Comme quoi ca doit fait la différence sur la piste, même si certain dise que ca crame un peu les moteurs
Que veux tu dire par "ca crame un peu les moteurs" ?
La durée de vie est raccourcie de part la surchauffe ?
Oui, c'est ca mais je dit bien que c'est ce que j'ai entends car j'ai jamais utliser ce type de vario ...
Enfin je vais attendre ce nouveau vario :rolleyes:
Ca crame les moteurs, mais ton 10.5 ressemble facile a un 7.5....voir 6.5....
Il faut juste faire attention a la chauffe, les programmes "8", ou sur les new "10" de chez LRP ne sont pas tendre avec les moteurs non plus...
Il me tente bien ce vario, par contre, onbligé de mettre des condos?
perso avec mon GT1.1 sur mon TT j'avais pas la place de mettre la barette de condo et je ne voyais pas la différence, apres le TT c'est pas du DTM,je débute en TT...
Ok merci.
Des avis de ceux qui roulent en DTM ou autre? Merci
Il parait que en DTM on vois une différence. En puch comme en vitesse de pointe
Il disent que c'est la bonne taille pour les 1/12eme mais est ce que ca fonctionne en 1s lipo?
Justement, ca fait partie des infos attendues :
- tension mini maxi
- type de moteur...
une idée de la date de disponibilité en france?
ca peux bien marcher avec un 10.5 ca....
seb
Oui, mais il ne faut je pense pas l'espérer avant fin février / début mars chez nos shop
Dispo depuis 1 mois, annoncé depuis 2. C'est plus 100% nouveau du coup !
CB, une idée de la date de mise sur le marché?
seb
il est dispo en france, je roule avec depuis 2 semaines ;)
Je viens d'avoir l'importateur français, il n'en a jamais eu et n'a pas de date d'arrivée prévue.
je vient de le trouver en france a moins de 165 euros !
:winner:
:winner:
le fait que tu en trouve en france ne veux pas dire que le vendeur soit passé par l'importateur français . Le truc c'est que si tu as un souci avec tu auras plus de souci pour le faire réparer . En plus je suis pas sure que tu es la notice en français . -buveurs-
il n'y a pas d'importateur exclusif speed passion en france
et pour ma part mes vario speedpassion ne passent pas, par "l'importateur france" comme tu dis et pas de problème de sav
je sais pas trop si je dois le prendre comme une agression ??
Maintenant je ne fais que répondre a vilain en lui disant que le mag ou il as trouvé son vario n'est pas passé par "L'IMPORTATEUR FRANCAIS " pour s'approvisionner. il est passé par un importateur d'un autre pays mais pas L'importateur français . Et il y a bien qu'un seul importateur Français . Monsieur Blandin pourras confirmer si je ne trompe . -buveurs-
