edf84
DEX210 - New 4x2 chez DURANGO
955 posts in this topic
AVID’s Triad Slipper Clutch has had much success since it’s recent debut and has found its way into the vehicles of RC’s top drivers. This killer slipper is now available for the Durango DEX210 and made its debut at last months running of the Cactus Classic in Arizona with much success and positive feedback from the Durango team. You will be able to get popular spur gear sizes for both modified and stock racing and mesh perfectly with Robinson pinion gears. Check out Avid’s webpage (www.avidrc.com) frequently for the release date and availability the DEX210 Triad Slipper Clutch. – Joel Navarro
Here’s some verbiage and specs from the Avid website…
The new AVID Triad Slipper Clutch has several advantages over the current slipper offerings. The design allows the clutch to transmit power, yet still maintain a degree of slip without overheating. The amount of difference in the clutch can only be explained after running it. When racers run our clutch, and then switch back to standard, it becomes clear how many areas of the track the AVID clutch improves the car.
We are offering two kit setups to better suit your needs. The only difference between the Mod and Stock kits will be the spurs that are included. That’s right we are including two spurs in each kit with the Mod kit having 81/84 and the Stock 72/76/69/66.
Highlights
smoother throttle/brake feel in jumps as well as turns
consistent performance (jumps are the same every lap)
light weight, compact design (TRIAD 11.2g Vs. Stock 16.4g)
longer life with less maintenance
preview at nationals / avidrc.com
DEX210-Avid-Triad-0006.jpg?a9f921
http://www.petitrc.com/_forumphp/showthread.php?48774-DEX210-New-4x2-chez-DURANGO
Pour ton diff c'est pas nouveau, il faut mettre les inserts plastique sur les noix pour info durango vient de sortir des noix de diff plus longue va voir la photo ici
Alors, pas d autres reponses, je suis le seul a qui ca arrive ou quoi?
non tu es loin d'être le seul, perso j'ai monté les tiges dorées des amortisseurs qui sont plus courtes.
Made for all 210 series kits is the all new V2 steering rack. The main revision is the move to horizontal steering balls for more prices adjustment and bump steer control.
The RDRP 210 Series Low-Roll-Centre Suspension Mount Set is specially designed for the Team Durango 210 series vehicles including the DEX210, DEST210 and DESC210. The LRC suspension mounts lower the vehicle's rear roll centre by 2mm in order to improve handling on medium to low-grip surfaces or when running spec tyres. Included in the set are the RF suspension mount as well as three RR mounts in the form of the 0/3, 1.5/3 and 3/3 variant. All parts are machined from aircraft-quality 7075-T6 aluminium, come black anodised and laser-etched for easy identification and a cool factory look. The blocks are a direct fit on the RDRP0184 Plus11 DEX210 Aluminium Chassis. DEX210 buggies with standard or aftermarket chassis and the DEST210 and DESC210 may require some do-it-yourself work in the wishbone/chassis area in order to give enough clearance for the arms.
The Revolution Design 210 Series Aluminium Steering Plate R2 is specially designed for the Team Durango 210 series vehicles including the DEX210, DEST210 and DESC210. The plate is totally redesigned from scratch and sports a new vertical inner ball stud position. This in combination with a more central and lower position of the ball studs does away with the need to use countless shims on the outer steering blocks in order to achieve zero bumpsteer. The steering plate is a direct replacement for the stock part and is CNC-machined from aircraft-quality 7075-T6 aluminium and comes black anodised and laser-etched for easy identification and a cool factory look. The RDRP 210 Series Aluminium Steering Plate R2 is a direct fit on the Team Durango DEX210, DEST210 and DESC210.
TYB015 HIGH GRADE BALL BEARING SET (DEX210/18pcs)
TYB016 CERAMIC BALL 3.0mm (14pcs)
TYTD063 MOS COATED BIG BORE SHOCK CONVERSION SET (DEX210/410/FRONT)
TYTD064 MOS COATED BIG BORE SHOCK CONVERSION SET (DEX210/410/REAR)
TYTD065 GRAPHITE STEERING PLATE (DEX210)
TYTD066 ALIMINUM BATTERY THUMB NUT (RED/2pcs/DEX210)
TYTD071 SLIPPER HUB & LAY SHAFT SET for GENERIC SPUR GEAR (DEX210)
TYTD075 ALUMINUM BIG BORE SHOCK PRELOAD NUT (RED/4pcs/DEX210/410/DESC410R)
TYTD076 ALUMINUM 14mm HEX WHEEL HUB CLAMP TYPE (RED/2pcs/DEX210/410)
TYTD078 ALUMINUM RF SUSPENSION HANGER (KICK-UP 2deg./DEX210)
TYTD079 ALUMINUM FRONT BULKHEAD (RED/DEX210)
TYTD080 MACHINED HEATSINK MOTORPLATE (RED/DEX210/7075)
TYTD095 ALUMINUM WASHER SET (RED/26pcs/DEX210)
TYTD096 ALUMINUM WING WASHER (RED/2pcs/DEX210)
TYTD100 ALUMINUM FRONT AXLE SCREW (2pcs/DEX210)
TYTD101 ALUMINUM FRONT TOP DECK MOUNT BUTTON (2pcs/RED/DEX210)
TYTD103 ALUMINUM RR SUSPENSION HANGER (Toe-In +0.5deg. /DEX210) / (Toe-In +1.0deg. /DEX210)
TYTD105 GRAPHITE UPPER LINK MOUNT SET (REAR/DEX210)
TYTD117 ALUMINUM REAR HUB CARRIER (RED/DEX210)
TYTD121 HEAVY DUTY AXLE SHAFT (2pcs/DEX210)
TYTD123 WOVEN GRAPHITE SHOCK TOWER TYPE TY (REAR/4mm/DEX210)
TYTD125 WOVEN GRAPHITE SHOCK TOWER SET TYPE TY (FRONT/4mm/DEX210)
TYTD126 WOVEN GRAPHITE BATTERY PLATE SET (DEX210)
TYTD131 ALUMINIUM SHOCK SEAL CAP (4pcs/RED/DEX210/DEX410/DESC210R/DESC410R)
TYTD132 ALUMINUM STEERING BELLCRANK SET (RED/DEX210/DESC210/DEST210)
TYTD133 ALUMINUM SHOCK MOUNT (10mm/4pcs/RED/DEX210/DEX410/DESC210/DESC410/DEST210)
TYTD134 A7075 MACHINED CUT LONG CHASSIS SET (+10mm/SILVER/DEX210)
Barre d'ackerman REVOLUTION DESIGN
Voici le montage de la barre d'ackerman pour Team Durango Dex210.
J'utilisais jusqu'à présent la barre Atomic Carbon sur mon "rear", lors du montage du châssis +11, je me suis aperçu qu'elle touchait la cellule avant, les perçages du renvoi sont apparemment au même endroit, bref je n'ai pas vu d'ou pouvait venir le problème.
Comme toutes les pièces Révolution Désign, la qualité et finition est nickel.
On peut voir sur cette photo la différence de longueur entre les deux barres.
Le montage est terminé, direction libre et çà ne touche plus la cellule.
http://jrtracing.blogspot.fr/2013/05/barre-dackerman-revolution-design.html
barre d'ackerman bis
Suite à la remarque de Christophe (merci), j'ai repris le montage de la barre pour la monter comme sur la photo RD, je confirme deux choses.
les boules, dans cette configuration touchent la cellule et les ressorts d'amortisseurs, mais!!!!! j'ai des boules Kyosho plus longue de 1mm par apport à l'origine, je pense que le problème vient de là.
J'ai donc travaillé un peu la cellule pour corriger çà et inversé la rotule du pied d'amortisseur pour décaler un peu l'amortisseur.
Une chose aussi, je suis dans la config réglage la plus désavantageuse, les étrier sont complètement devant.
La barre, avec les rotules devant et le bossage de rotule.
La cellule retravaillé pour que les rotules ne touchent pas.
La rotule avec la surface d'appui a été diminué.
J'ai diminué le bossage et la rotule pour avoir un débattement symétrique à droite et à gauche.
La rotule du pied d'amortisseur inversé.
Comme çà l'amortisseur est à 1 mm environ de la barre.
De rien.
Sinon ce n'était pas plus simple de limer un peu la barre RDRP pour recentrer la boule et de garder tout le reste d'origine ?
Christophe alias foch78
La barre a aussi été limer pour avoir un braquage identique, la diminution du bossage ne suffisait pas ;)
http://jrtracing.blogspot.fr/2013/05/barre-dackerman-bis.html
This high quality Machined Spur Gear is precision designed to provide ultra-durable and consistent gear action.
Features: Machined tooth construction for perfect gear meshing - Machined internal flange for increased durability
MACHINED SPUR GEAR 72T (48DP)
Part No: TD310441
MACHINED SPUR GEAR 69T (48DP)
Part No: TD310442
ALUMINUM BIG BORE SHOCK SPRING RETAINING COLLAR (RED/4pcs)
* Product specifications are subject to change without notice.
The aluminum big bore shock spring retaining collars for DEX210, DEX410, DESC210, DESC410, and DEST210.
It brings you perfect performance of the shocks and gives you better performance.
Holes designed for lightweight and dust prevention.
Anodized in "Tresrey-Red".
DEX210 +8MM CARBON CHASSIS SET
Heavy duty performance race chassis for the DEX210.
Extra lightweight for more nimble response and with slightly more flex then the alloy chassis for increased overall grip to take advantage of the lighter weight.
+8mm chassis that includes alloy side plate extenders.
Includes a 7075 alloy nose plate for longer wear and extra strength at the chassis bend.
Chassis is made of 2.5mm thick USA made and machined carbon fiber.
Machined pockets at the rear of the chassis allows the use of LRC option suspension hangers.
Increased rear end surface area maintains chassis strength for mounting of the rear suspension hanger.
The chassis set is almost 1oz (26gr) lighter then the stock alloy chassis!
Requires part TD320122 Chassis Side Pod and TD320124 Side Mounts if you are not running the stock alloy chassis set currently.
http://www.exotekracing.com
les evolutions du dex210 lors de l'euro
  • New front geomerty
  • New steering link (shorter)
  • New bracket (?) on rear
image: antoine rossetti
Merci richard!
nos amis british viennent d afficher le 210 a moins de 100£, ca sent un nouveau 4x2 ou plutot une grosse evolution du modele existant!
Qui a plus d'info sur la sortie d'un nouveau DEX210 "V2" et DEX410 "V4"??
je voudrais savoir de quelle coté se trouve la vis coté téte pour le resserrage et réglage du diff sur le montage MID MOTOR MM4 je pense la voir sur la notice coté gauche coté couronne et pignon moteur
merci de me lire et de me donner votre avis et votre connaissance
