Tamiya F104 & F104 v2
713 posts in this topic
Ca doit deja etre sorti, vu que le chassis de la photo est tout rayé :tourne:
wow,et T2M ils attendant quoi pour refaire des Tamiya Cup?! ya des gens qui ont envi de rouler XD
ben vous pouvez déjà faire la tarmac cup :D
C'est quoi la Tarmac Cup???
(Je suis le nouveau membre qui est venu se présenter l'autre jour au circuit)
Une course pour les amateurs de planches à roulette à pneu mousse
La fiche de renseignements est en première page.
RC F104 PRO w/Body (Item #58431)
With the release of the limited edition 1/10 R/C F103 15th Anniversary Chassis Kit (Item 84056) and F103RM Chassis cars, popularity in this type of R/C model has swelled all around the world. Tamiya is proud to release the newly designed F104 chassis. Events such as Tamiya Grand Prix now feature F103 & F104 class races.
# The first edition of the F104 chassis kit comes in PRO specifications and uses top-quality carbon fiber parts for a beautiful finish.
# The car features front & rear wings and an original body, which produce a great scale realism.
# Tire size and body dimensions mimic those seen in races.-The battery is longitudinally-mounted for a slim body design.
# The 2WD Direct Drive system has excellent acceleration qualities and is very reliable.
# The front suspension features a link-type coil spring with the rear suspension having a friction plate & a T-bar set up with a TRF damper.
# A part of the new design is the aluminum diff housing. Even if your wheels are removed,the differential will hold together allowing easy maintenance.
# The height adjustable rear gear case has been designed to match the new tire dimensions.
# The isometric steering rod links up well with the longitudinally-mounted steering servo for excellent control.
# The car features a low number of parts allowing for simple operation and easy maintenance.-Type 540 motor included.
# ESC, 2-channel R/C system, battery pack & charger are separately required.
Tamiya
So the big question is " Will my F103R go limp on the grid next to the F104?"
Well yesterday at the Shizouka Hobby show here in Japan we had a chance to see the car and meet the designer.
Looking at the pictures of the car in magazines the chassis didn't look like much. Seeing it in person and get the talk with the designer shined a light on a few things.
"How do you get the battery in and out?" Most of the cars with center batteries require some wrenching to get the battery out. The F104 has a very slick system to remove and replace the battery. Take a quick look at the picture on the left.
The battery acts as a lever of sorts for the receiver and speed control mounts pivot. To put the battery in you slide it in at an angle,as the battery is moved to the rear and centered the receiver and speed control move with the battery to line them back up.When the battery is completely moved back into its cradle a lock held in with two body clips is installed. That's it. It take about two seconds.
More... / Plus...
bonsoir je souhaite ouvrir ce sujet pourcommuniquer sur ce suberbe chassis a venir chez tamtam.Echange d infos dispo prix categorie en course ou juste lousirs retour tamcup etcpimg.htm
Ben j'ai hate que tu me dises ce que tu en penses
salut a tous
c'est bien ce que j'avais vue les pneus ont l'air moins large (a l'arriere) et de plus grand diametre
dommage.
a plusssssssss
un peu de patience, la belle s'est se faire désirer
la voiture en image n'est pas celle de nocif!
voici la Tamiya F104 PRO mise sur le marché public depuis hier comme annoncée.
Published the 21th of April on Petit rc, the Tamiya F104 PRO is now official. Have a look to pictures below.
By Tamiya
