HPI Racing - Formula Ten
50 posts in this topic
Ca a le mérite d'être réaliste
J'espère qu'on pourra y monter des pneus Tam!
Enfin une F1 qui ressemble à une F1. Bravo HPI!!!
En tout cas ça doit être joli à voir rouler!
Une idée du prix?
HPI are extremely proud to debut a fantastic new kit designed to replicate the thrills and excitement of the fastest car racing series in the world: the Formula Ten! Since the release of the original Super F1, HPI's first-ever car kit, HPI have been waiting for the ideal opportunity to release an all-new chassis designed around the most exciting and glamorous racing cars the world has ever seen!
The Formula Ten features realistically scaled dimensions such as wheelbase, width, tyre size and more, allowing you to faithfully recreate your favourite team's livery and do battle with rivals out on the track. There is truly nothing like the excitement of seeing a full grid of cars painted in replica colours, waiting for the lights to go out!
Completing the amazing scale detail is the awesome 5-piece polycarbonate bodyshell, which features a variety of scoops, winglets and barge boards that allow you to make it into your favourite racing team from the 'winglet and chimney' era! Soon, you'll also be able to easily replicate the design and total look of your favourite Formula One car, team or driver from other classic eras of Formula One!
Mirage UK
A votre avis, on pourra y monter des accus standard (7.2V) et non pas 4.8V ?
J'avoue que j'hésite beaucoup entre ce modèle et une bonne veille F103 GT...
Salut, à en voir cette photo je dirais que oui ;)
PS: A quand des courses d'F1 Electrique ? :D
c'est en cours!!! regarde du côté de chez Asia Racing Team :winner:
A priori c'est pas gagné vu ce que dit HPI sur son site: :wouinn:
Add your own radio transmitter, steering servo, receiver, electronic speed controller (ESC), standard-size 540 motor, 4-cell 4.8v stick-pack battery with charger...
Ouai et vu les photos des packs aussi... autant se tourner vers la f104 pro qui doit être en plus moins chère...
Nan je pense qu'on peut mettre des 6cell vu les 'expansion' sur celle de gauche en orange par rapport a celle qui est a coter qu'on voit a moitier ... ! Il y a juste a changer la fermeture pour le packs...
en même temps, pourquoi n'ont-ils pas prévu un emplacement adapté au lipo, ce serait plus d'actualité...
Kit de modification HPI Formula Ten 1/10
* Yeah Racing Aluminum Knuckle Arm (OR) x 2 pcs
* Yeah Racing Aluminum Motor Mount Single Piece (OR) x 1 set
* Yeah Racing Aluminum Rear Main Drive Shaft (OR) x 1 pc
* Yeah Racing Aluminum Steering Post (OR) x 1 set
* Yeah Racing Aluminum Body Post Set (OR) x 1 set
* Yeah Racing Aluminum Servo Arm (OR) x 1 set
* Yeah Racing Aluminum Steering Arm (OR) x 1 set
* Yeah Racing 1.4mm FRP T Bar (GN) x 1 pc
* Yeah Racing 1.6mm FRP T Bar (GN) x 1 pc
* Free Yeah Racing Sticker Style 2 x 2 pcs
* Yeah Racing Metal Bearing Set x 1 set
* Yeah Racing 5 x 10 x 4mm Bearing X 4 Pcs
* Yeah Racing 4 x 7 x 2.5mm Bearing X 2 Pcs
* Yeah Racing 1/4″ x 3/8″ x 1/8″inch Bearing X 2 Pcs
encore des nouveautés
#103023 ALUMINUM STEERING KNUCKLE SET (FOAM TIRE/ORANGE)
Maximize the handling of your foam tire equipped HPI Formula Ten car with this Aluminum Steering Knuckle Set. The steering knuckles are precision machined from billet aluminum for durability and feature additional steering link locations to help dial in the steering response to track conditions. Both arms are anodized bright orange for custom looks. The wheel shafts for this set are made specifically for the HPI FT02 wheels for use with foam tires. Four low friction ball bearings for the front wheels are included.
* #102915 FT02 WHEEL SET (FOR FOAM, BLACK, FRONT 2pcs)
* #102917 BALL DIFF SET FOR FOAM WHEELS (95 TOOTH, 64 PITCH)
* #103015 FT02 WHEEL SET (FOR FOAM, BLACK, REAR 2pcs)
* #103023 ALUMINUM STEERING KNUCKLE SET (FOAM TIRE, ORANGE)
#102917 BALL DIFF SET FOR FOAM WHEELS (95 TOOTH/64 PITCH)
HPI Formula Ten car owners using foam tires can now modify their cars with this Ball Differential Set that allows quick and easy tuning of the differential to track conditions for optimal handling. The set contains an aluminum axle and two lightweight aluminum hubs that are anodized in bright orange, D ring washers, ball bearings, diff grease, a 95T spur gear, and legendary tungsten carbide diff balls for the ultimate in durability and precision. The smooth and efficient diff action gives extra traction for lower lap times. This set requires the use of HPI wheels for foam tires (102915 Front and 103015 Rear).
http://www.youtube.com/watch?v=TrVZTgj5AUk
http://www.hpiracing.com/videoplayer/67/
http://www.hpiracing.com/newstuff/102851/
c'était a quel sujet déjà une Renault qui tape le mur,bon est-ce qu'il y aura d'autre stickers que Renault
je voudrais avoir une bonne configue de f1 en brushed pour faire de la compète !
tour moteur et companie!
Car la je comprend pas g une vario lrp +10t , un moteur lrp v10 spec 4 12x2 (41000 tour min) et avec un accus lrp lonlife 5000 mah, g mm pas 5 min d'autonomie.
merçi de votre aide
Il n'y a plus de f1 depuis longtemps en "compet", la caté est morte un peu avant le groupeC il y a 10 ans environ. A cet époque en 3000 GC on faisait l'autonomie, juste mais on la faisait, avec des moteurs environ 12t (et plus bas en worlds car 4 min)
Partir donc sur du bon pack à partir de 5000mah en lipo, et du brushless en 6.5 maxi, ou, comme vous le demandez, du 12t environ (là encore de bonne facture pour le rendement)
il y a pas de compet ? et les 104, 103 donc je vois les courses ? c'est quoi, juste des rencontre ?
Ou c'est des Tamiya Cups...
merçi de votre aide
Il y a un problème sur ta config, avec un 12 tours nous faisons plus de 12 mn avec un pack 4600 en 6 éléments.
Si tu as les mêmes symptômes avec différents packs, il y a soit un problème de vario, soit un rapport vraiement inadapté.
Quel est ton rapport ?
Le palier après 5 mn est il brutal ou progressif ?
