alex
Schumacher MI4
106 posts in this topic
mon avis ben deja elle est tres directrice de boites a haute comme basse vitesse.
L'ajout des nouveaux triangles courts et des étriers ultra flex permet un gain supplémentaire de directivite à haute vitesse
Qui a déjà testé le set-up carpet-rubber dispo sur le site Schum ? Qu'en est-il ressorti à l'égard du comportement de la voiture ?
Jérôme
Mi4 Upper Link Plate
Developed with leading local Schumacher drivers, the Smokem Mi4 Upper Link Plate provides Schumacher Mi4 racers with additional, longer upper link positions to dial in their cars. By incorporating multiple link positions, racers can alter the length of the upper link without changing the upper link plate. Apart from the standard 39.2mm spacing, there are 2 additional spacings of 31.7mm and 24.2mm.
Running a longer upper link provides greater roll resistance for a given spring rate and less camber rise. It is also ideal when running harder carcass control tyres by maximizing tyre contact patch and maintaining consistent tyre wear. Removing the shock tower is recommended to simplify installation.
Suits Schumacher Mi4 and Mi4LP.
