#1
Ancien 14/06/2008, 06h06
Avatar de Reporter
Reporter Reporter est connecté en ce moment
Super Moderator
Inscrit : décembre 2006
Images: 1899
Reporter n'a pas encore de réputation
Team Associated Factory Team RC10R5
Team Associated releases his new 1:10 200mm Pan Car, the Factory Team RC10R5 based on the Factory Team RC12R5.
This is so a new contender in this category and it will be interesting to see those car evolving in race condition as all rules must be defined in term of motors and battery as others.
Clic pictures to get them larger.
The new Factory Team RC10R5 is Team Associated’s entry into the fast-growing 1:10 scale World GT onroad racing class. With Team Associated’s twenty-five years of 1:12 and 1:10 scale onroad racing history, we are very excited to offer the Factory Team RC10R5 to this new emerging class!
Starting with the highly successful RC12R5 platform, the designers in Area-51 built the bigger RC10R5 on a 2.5mm woven carbon fiber chassis that utilizes a pivot-ball link rear suspension that allows for independent adjustments for chassis roll, bump and alignment.
Having the ability to make these chassis adjustments independently gives the RC10R5 greater potential to get the best possible handling from the car and the track surface. While testing, the pivot ball-link chassis has proven to be more durable in high speed impacts and much better in bumpy track conditions.
The RC10R5 features new shocks that have a through-shaft design, making for equalized damping throughout the full stroke of the shock in both directions, without any unwanted rebound. The center shock tower has four mounting positions that split the spring rates for even finer adjustments. The new center shock also controls the chassis droop and can be adjusted on the car with a turnbuckle wrench, making it easier and quicker to get dialed in.
The RC10R5’s ‘Active Strut’ front end has been optimized, featuring symmetric components with adjustable caster and track width, as well as a new front axle with wheel nut. Factory Team blue aluminum servo mounts position the servo flat on the chassis for a lower center of gravity and include Ackermann adjustment spacers.
The foam front bumper helps protect body and chassis during impacts.
The RC10R5 features a wide rear pod optimized and balanced for brushless, woven carbon fiber top plate, and Factory Team blue aluminum machined motor mount and left-side bulkhead. The woven carbon fiber top plate attaches to the motor mount and leftside bulkhead at four points, making the RC10R5’s rear pod more rigid and durable.
The RC10R5 uses 90% of the same parts as the RC12R5, making it easier than ever for current 1:12 scale racers to jump into the fun of bigger cars with scale bodies that is the World GT class.
RC10R5 Factory Team features:
• Designed to fit World GT racing class specs
• Wide rear pod is balance-optimized for brushless motors and features Factory Team blue aluminum machined motor mount and left bulkhead
• New Factory Team pivot ball-link chassis allows for independent adjustment for roll, bump, and alignment
• The pivot ball-link chassis has proven to be more durable in high speed impacts and better in bumpy track conditions
• New Factory Team shocks feature a through-shaft design, making for equal damping with no rebound in both directions
• Updated active strut front end features symmetric components with adjustable caster and track width, as well as a new front axle with wheel nut
• Woven carbon fiber center shock tower allows for incremental adjustments of rear spring rate
• 2.5mm woven carbon fiber chassis
• Full ball bearing
• Ball differential
• Foam front bumper helps protect body and chassis
• during impact
• Servo mounts flat for a lower CG and includes Ackermann adjustment spacers
Team Associated
__________________
If an article is published in a language different from your mother tongue, make yourself sure you can understand the content!
Si un article est publié dans une langue différente de votre langue maternelle, faites en sorte que vous puissiez comprendre le contenu par vous même!
Répondre en citant
  #2
Ancien 22/06/2008, 16h01
Avatar de heretic
heretic heretic est déconnecté
Expert **
Inscrit : juillet 2003
heretic n'a pas encore de réputation
rc10 r5
super
Dernière modification de heretic, 22/06/2008 à 20h52
Répondre en citant
  #3
Ancien 23/06/2008, 00h26
Avatar de Assam
Assam Assam est déconnecté
Espoir
Inscrit : septembre 2007
Assam n'a pas encore de réputation
Re : Team Associated Factory Team RC10R5
asso investi vraiment chez renault, deux r5 pour le prix d'une !!
Répondre en citant
  #4
Ancien 03/09/2008, 20h57
Avatar de eric
eric eric est déconnecté
Expert **
Inscrit : janvier 2002
eric n'a pas encore de réputation
pas mal du tout...
Répondre en citant
  #5
Ancien 05/09/2008, 03h03
Avatar de Reporter
Super Moderator
Images: 1899
Images attachées
Type de fichier : jpg 364956709_Xp9EK-XXXL-1.jpg (295,7 Ko, 55 téléchargements)
__________________
Répondre en citant
  #6
Ancien 05/09/2008, 14h58
Airwave Airwave est déconnecté
Expert **
Inscrit : juin 2002
Airwave a une "POSITIVE attitude"
Le hot-linking a pas la vie belle ces temps-ci... deja deux news ou les photos marchent pas...
Répondre en citant
  #7
Ancien 25/09/2008, 23h25
Avatar de Christophe Blandin
Christophe Blandin Christophe Blandin est déconnecté
Partenaire commercial PETIT R/C
Images: 22
Christophe Blandin a une "POSITIVE attitude"
10r5
Enfin dispo en France
__________________
SELECT MODELS (SMS), MAGASIN de modélisme R/C en VPC, partenaire officiel de PETIT R/C
Tél. : 04 78 64 06 20 (N° non surtaxé) N'hésitez pas à appeler. Expédition le jour même! (ouvert toute l'année). Si urgence : 0609974512 Fax : 04 78 64 04 09 (24h/24)
Tout en stock pour l'électrique, en Vente Par Correspondance 24H. Pour tous achats R/C, appelez nous : A votre service depuis 1992. Since 1992. Spécialiste électrique depuis 1980. Facilités de paiement (4 fois, sans frais). Cartes Bancaires, débit à expédition, vous ne payez rien d'avance. Arrivages quotidiens.
Trinity • Orion • MIP • Novak • HPI • Schumacher • Corally • Proline • Yokomo • Protoform • Andy’s • Ride • Take Off • Paragon • Dahm’s • PK • Race Tech • Race Craft • RW • Edge • TRC • LRP • Bud’s • HML • Ellegi • Sanwa • Keil • Pete’s • Racer Choice • Thunder Design • CS • Hudy • Graupner • Select Models • Traxxas • Ballistic • M. Troniks • Pactra • Infinity • Tekin • Kimbro • Twister • Tamiya • Fastrax • Kawada • Kyosho • Cobra • GM • Badd Boyz • Factory Team • Frewer • Kose • PB • Pure Tech • Sanyo • Maxtec • Niftech • IRS • Carson • Robitronic • Pit Shimizu • Peak Perf • Reedy • Lunsford • Enetti • Médial Pro • Futaba • RPM • Nosram • Losi • KO • Asso • JC Racing • Echo • RCPS • Powers • JB • Panasonic • Fantom • TNT • SMC • TeamMagic • Keyence • alclad • Hara • GP • Electronic Model • Sorex • 3 Racing • Spectrum • Grp • Tamiya • Roche • Bold • Cml • Wurtz • Speedmind • atelsis • Eagle • Black art • crc • Castle creations • Spintech • Teknipron • Atomic carbon • Laje • Intellect • ip • Fish • Rcedge • Titanium racing • Xenon • HB • east cost • azarashi • Kanzen • JC concept • spazstic • Matrix • Grepow • Xfactory • Speed passion • Core rc • Jaco • Checkpoint • Eds • Fastcolor • RCcar • Rc edit • Rheinard • Moebers • DDP • Vampire • EnerG • Optimized • Kfactory • Xray • East Power • Vtech • Xceed • factory parts • deans • IP • Sweep • Much more • team bomber • SIB • Laje • Lipotec • M Racing • Spec R • mix etc. (Tout ou partie des produits de ces marques). Stock permanent conséquent (Accus, moteurs, variateurs, chargeurs, kits, radio/servos, pièces, pneus, peintures, accessoires, carros, produits pneus, etc.); Conseils, compétence, sérieux. Spécialiste 1/12è, groupe C, DTM et TT, lipos et brushless. Adresse postale : Select Models bp9161 69263 Lyon cedex 09. Adresse magasin : 78 rue St Pierre de Vaise 69009 LYON France
Adresse courriel : c.blandin@selectmodelsshop.com (n' utilisez pas MP pour nous contacter, encore moins messages du profil, do not use PM, no mensaje privado por favor)
www.selectmodelsshop.com
www.selectmodels.fr
(vente directe de quelques produits spécifiques, KANZEN par exemple, réglement en ligne)
www.xfactory.fr
www.azarashi.fr www.corally.com www.jaco-pneus.fr
selectmodels.blogspot.com
VOYEZ TOUTES NOS NEWS (cliquez sur la croix)-->
Répondre en citant
  #8
Ancien 12/03/2009, 11h50
Avatar de litchy
litchy litchy est déconnecté
Espoir
Inscrit : septembre 2008
litchy n'a pas encore de réputation
un ptit up!
il y a t'il des avis de personne qui ce serait laissé tenter par ce kit?
Répondre en citant
  #9
Ancien 14/03/2009, 16h00
Avatar de Kerb
Kerb Kerb est déconnecté
Expert **
Inscrit : mai 2005
Kerb n'a pas encore de réputation
Je suis à deux doigts... Reste plus que mon détaillant préféré fasse rentrer des pneus et je pense que je vais me lancer !
Répondre en citant
  #10
Ancien 24/03/2009, 09h33
Avatar de piertiss
piertiss piertiss est déconnecté
Expert *
Inscrit : mai 2004
piertiss n'a pas encore de réputation
Citation:
Envoyé par Kerb Voir le message
Et tu compte rouler avec des 4éléments ou LIPO?
j'aimerais savoir si certain roule en lipo avec ce chassis et comment on t'il fait pour caser le pack? L'adaptation a l'air moins facile que sur la CRC
Répondre en citant
  #11
Ancien 24/03/2009, 20h36
Avatar de Kerb
Expert **
Inscrit : mai 2005
A priori avec des lipo saddle... ça doit pouvoir s'adapter non ?
Répondre en citant
  #12
Ancien 24/03/2009, 21h02
Avatar de piertiss
Expert *
Inscrit : mai 2004
je me posait la question pour les lipo en stick en fait, car j'en ai deja pour le dtm
Répondre en citant
  #13
Ancien 24/03/2009, 21h12
Avatar de piertiss
Expert *
Inscrit : mai 2004
je viens de trouver la reponse a ma question lol en fait ça passe mais dans la longueur...
Répondre en citant
  #14
Ancien 08/04/2009, 13h33
Avatar de Kerb
Expert **
Inscrit : mai 2005
Bon, j'ai la mienne !
Il y a d'autres possesseurs de ce châssis pour échanger des tuyaux ?
Répondre en citant
  #15
Ancien 17/05/2009, 19h06
Avatar de Reporter
Super Moderator
Images: 1899
RC10R5 Converion Kit to Lipo and 235mm front end
RC10R5 LiPo conversion kit
The kit can accommodate different thicknesses of LiPo pack, and different configurations such as stick or saddle styles. NiMh cells can also be fitted. To retain the pack, cell tape is used through the original battery slots, and an extra loop can be placed through the chassis lightening holes.
[IMG][/IMG]
To be honest, this should be a factory standard option. These cars are begging for more power than 4 cell. There's so much space on the chassis, a 6 cell pack or LiPo fits easily with enough space for plenty of other gear. On LiPos and a decent brushless power system the R5 is a rocket ship.
To fit this kit you will not need to modify the chassis or anything else in any way. You can return to the standard 4 cell configuration easily.
WHAT YOU GET:
2mm woven carbon fibre bridge with 4 shock mounting options
Relocated antenna mount position
Machined aluminium bridge supports
All mounting screws
RC10R5 235mm front end conversion
Punch the car out to a full 235mm to run it as a true Pro-10. Bring back the days of 75mph finals and marshals in hockey gear!
The primary subframe is machined out of 3mm solid carbon. To increase the strength and stiffness the 2mm tie bar is re-profiled to better take the buckling loads. You still need to widen the rear track with offset hubs to bring the back end out to the same width.
WHAT YOU GET:
2mm woven carbon fibre tie bar
3mm woven carbon fibre subframe
Fulloption
__________________
Répondre en citant
  #16
Ancien 23/05/2009, 05h24
Avatar de Reporter
Super Moderator
Images: 1899
Re : RC10R5 Converion Kit to Lipo and 235mm front end
__________________
Répondre en citant
  #17
Ancien 23/05/2009, 12h05
Avatar de fanaom
fanaom fanaom est déconnecté
Expert **
fanaom a une "POSITIVE attitude"
Cette solution est elle envisageable sur le 12R5? Ca passerait sous la caro?
Répondre en citant
  #18
Ancien 26/05/2009, 05h24
Avatar de Reporter
Super Moderator
Images: 1899
__________________
Répondre en citant
  #19
Ancien 26/05/2009, 08h57
Avatar de fanaom
Expert **
on peut aussi remarquer que le proprio de l'auto a vite viré l'amortos d'origine merdiique
Répondre en citant
  #20
Ancien 15/06/2009, 13h47
cbombabill cbombabill est déconnecté
Débutant sur le forum
Inscrit : septembre 2005
cbombabill n'a pas encore de réputation
ptit question sur se genre de model c est les meme pneu que pour les 1/12 qui sont utilisé ?ou c est carément d autre ?
Répondre en citant
Répondre
Utilisateurs lisant actuellement ce sujet : 1 (0 membre(s) et 1 visiteur(s))
Outils du sujet
Affichage du sujet
Règles des messages
Vous ne pouvez pas créer de sujets
Vous ne pouvez pas répondre aux sujets
Vous ne pouvez pas importer de fichiers joints
Vous ne pouvez pas modifier vos messages
BB codes : Activé
Smileys : Activé
BB code [IMG] : Activé
Code HTML : Désactivé
Navigation du forum
Sujets similaires
Sujet Auteur du sujet Forum Réponses Dernier message
Team Associated RC8 / RC8T Reporter Technique 19 08/07/2010 09h33
Associated Factory Team 12R5.1 nocif13 News / Nouveautés 5 22/08/2009 10h56
Team Associated RC10R5-Oval Factory Team Kit Reporter News / Nouveautés 0 15/05/2009 23h38
Paul Sinclair X Factory Race Team Manager seb69b4ft News / Nouveautés 0 08/01/2009 11h48
EIR 2009, les inscriptions sont lancées ........ Dadandson Belgique / Belgium 7 02/01/2009 18h04
Fuseau horaire : GMT +2. Il est 05h18.
Propulsé par vBulletin® version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Version française par vBulletin-Ressources.com
PETIT R/C est une association à but NON LUCRATIF enregistrée sous le numéro 0953016656
