Features
  • New "pitbull" clear lexan body.
  • Single pack layout for perfect weight balance.
  • Easy maintenance and safety cable position for electronic components.
  • CNC aluminium motor mount in 2 pieces for easy motor maintenance.
  • Super safety battery box.
  • Narrow 3mm lightwheight chassis plate design with optimal weight distribution and ultra low center of gravity.
  • CNC machined 7075 T6 lightwheight front and rear adjustable toe-in plate with insert. The STR8 Spirit is fully adjustable in a number of ways.
  • New center differential mounting system for easy maintenance.
  • Teflon sealed bearing to use lighter ball bearing (14x8x4mm).
  • New special hard body shock treatment for smoother friction.
  • New radio tray monting system, is easily removed for cleaning.
  • Molded composite waterproof receiver box.
  • CNC machined 7075 T6, lightwheight aluminium one piece front top plate including adjustable insert.
  • New Steering geometry for more consistency throught the rough and reduced bump-steer.
  • New wing generates powerful down force.
  • Extra light front and rear carbon fiber suspension towers (4mm).
  • Lightwheight steel CVD drive-shaft with captured hinge pin system for highest security during racing.
  • New lightweight center diff cup and brake disc with more driving plate.
  • Adustable linkage for brake system, brake distribution change easily forward to backward.
  • Front and rear anti roll bar.
  • New gear case system for easy maintenance.
  • Front and rear flexible composite brace.
  • Lightweight diff cup for front, center and rear differential.
  • Safety 7 mm ball and new plastic ball end for steering.
  • CNC Machined 7075 T6 rear hub with 1° toe-in included.
  • CNC Machined 7075 T6 new steering knuckles.
  • Front and rear lower arm with new design and exactly compound and composite ratio.
  • CNC helicoidal gear for front and rear (13/43).
  • Center 44T lightweight spur gear.
  • Adjustable turnbuckles linkages.
  • Nouvelle carrosserie transparente "pit bull".
  • Un seul boitier de batterie pour une répartition des masses parfaite.
  • Multiples points de fixation des câbles pour une meilleure gestion de l'électronique.
  • Support moteur 2 pièces en aluminium usiné CNC.
  • Boitier d'accus Lipo 3S / 4S ou 6S souple ultra résistant" pour batterie à coque souple ou rigide.
  • Châssis 3mm allégé et déssiné pour une répartition des masses optimales.
  • Cales de pincement et d'anticabrage en aluminium usinées (7075 T6) et allégées, équipées d'inserts. Le STR8 Spirit est réglable dans tous les sens grâce aux inserts.
  • Insert en téflon pour monter des roulements plus petits (14x8x4mm).
  • Nouveau amortisseurs traité dur (un fonctionnement plus doux et moins d'usure).
  • Platine permettant un logement de l'accu de réception à l'avant ou à l'arrière (réglage du centrage des masses).
  • Platine avant en aluminium usinées (7075 T6) et allégées avec inserts.
  • Nouvelle géométrie de direction afin d'améliorer le braquage à haute vitesse.
  • Nouvelle aileron procurant plus d'appui.
  • Support d'amortisseurs en carbone ultra léger (4mm).
  • Cardans allégés avec goupille sécurisée, pour une fiabilité maximum.
  • Barre anti roulis avant et arrère.
  • Nouvelle cellule de transmission entièrement sécurisée grâce à des écrous nylstop noyé et permettant un démontage plus rapide des différentiels.
  • Renfort avant et arrière en composite.
  • Boule anti déchappage et nouvelles chappes de direction.
  • Fusées arriére en aluminium usinées (7075 T6) avec 1° de pincement in-board.
  • Nouvelles fusées avant en aluminium usinées (7075 T6).
  • Nouveaux triangles avant et arrière avec un nouveaux design et une nouvelle matière (ratio de fibres revu).
  • Couples et couronnes conique en acier usiné et à denture hélicoidal (13/43).
  • Couronne centrale 44 dents.
  • Tirants à pas inversés.
Technical Specifications :
Scale 1:8
Power Electric
Type Offroad
Lengh 507mm
Width 307mm
Wheelbase 320-328mm
Front and rear gear 13/43
Center gear 44
Weight 3200g
Drive 4WD
New "pitbull" clear lexan body / Nouvelle carroserie "pit-bull" transparente :
