Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 109
Thread: Hobbywing Xerun V3
  1. #1
    Join Date
    Dec 2006
    Posts
    17,793
    Images
    5687
    Hobbywing Xerun V3
    STRONGEST:* Most advanced software functions
    SIMPLEST:* Built-in electronic switch saves chassis space
    EASIEST:* Ten pre-set profiles for Plug and Play
    MOST RELIABLE:* Innovative heat dissipation structure
    XERUN-120A-V3 has 3 kind of color options:
    Blue edition:*** PN=81020310
    Black edition:** PN=81020320
    Red edition:*** *PN=81020330
    1* Specification
    Specification XERUN-120A-V3
    Current Continuous: 120A, Burst: 760A
    Input* * Note #1 *4-9 cells NiMH/NiCd or 2-3S LiPo
    Built-in BEC 6V@3A (linear mode)
    Resistance 0.0003 Ohm
    Motor Supported Sensored and sensorless brushless motor
    Suitable Motor With 2 Lipo or 4-6 NiMH
    *1/10 on-road: >=3.5T, 1/10 off-road:*>=5.5T
    With 3 Lipo or 7-9 NiMH
    1/10 on-road: >=5.5T,* 1/10 off-road: >=8.5T
    Suitable Car 1/10,1/12 all competitions
    1/10,1/8 rock crawler
    Cooling Fan 5V
    Size 37.5mm(L) * 31mm(W) * 29.5mm(H)
    Weight 93g
    * Note #1
    For 4-6 cells NiMH/NiCd or 2S LiPo, the standard cooling fan needn't be changed.
    For 7-9 cells NiMH/NiCd or 3S LiPo, the standard cooling fan need be changed to 12V high voltage fan.
    2* Features
    2.1 All in One. Up to ten profiles can be stored in the memory and imported or exported easily. Factory pre-set profiles include:
    Blinky mode, Modify Mode, Stock mode, Practice mode, Offroad mode, Drift mode, Crawler mode.
    2.2 Built-in Electronic Switch, long life and high reliability, also saves space on the chassis.
    2.3 Aluminum Upper Case with optional colors, giving better heat dissipation, and allowing higher current.
    2.4 External Programming Port (EPP), easy to connect and also a power port for additional fan.
    2.5 Advanced Dynamic Timing technology, providing more customization possibilities for highest level competitions.
    2.6 Precise throttle and brake control, setting of drag brake and brake strength with more options, new punch and brake rate control functions, and throttle and brake curves through the PC client.
    2.7 Integrated Data logger, recording the maximum temperature of ESC and motor as well as the maximum RPM, using LCD Programming box to check easily in the pits.
    2.8 Multi Protection Functions, making your running safe with ESC and Motor overheat protection, low voltage cutoff and throttle signal loss protection.
    2.9 Easily programmed with the Professional LCD Program Box and USB Link Software
    *(Note:*XERUN V3 ESC*ONLY works with the new version of the USB Link Software, that*is, the version not*ealier than V3.0_Beta_120401)
    2.10 New USB LINK Software graphic interface, providing extra parameters for advanced settings.
    2.11 ESC firmware can be updated through the USB adapter in the LCD Program Box.
    If an article is published in a language different from your mother tongue, make yourself sure you can understand the content!
    Si un article est publié dans une langue différente de votre langue maternelle, faites en sorte que vous puissiez comprendre le contenu par vous même!
  2. #2
    Join Date
    Dec 2006
    Posts
    17,793
    Images
    5687
    Re : Hobbywing Xerun V3
    ESC User Manual
    http://www.hobbywing.com/uploadfiles...l/HW-09-v3.pdf
    1. The Programmable Item List of the ESC.
    2. The default settings of 10 pre-set profiles in the ESC.
  3. #3
    Join Date
    Jan 2008
    Age
    44
    Posts
    125
    Salut a tous
    Merci pour les infos sur le V3, mais j'ai du mal avec l'anglai.
    Personne pour une explication ou une traduction sur le variateur et les 2 tableaux.
    Donc si il y a des personne qui parle couramment l’anglai, sa serai GOOL
    MERCI
    A + JPJ18
  4. #4
    Join Date
    Feb 2011
    Age
    38
    Posts
    1,343
    Images
    196
    Tu veux savoir quoi exactement, le premier tableau explique les diverses possibilitees du vario, le deuxieme te donne les reglages de base a appliquer en fonction des moteurs utilises.
  5. #5
    Join Date
    Jan 2008
    Age
    44
    Posts
    125
    Je pense que dans un premier temps de nous expliquée ou traduire les sections / progra item / et sud item
    Car avec un traducteur anglais / français (section est traduit section) (item = » article)….
    Apres il y a des choses évidentes à traduire :
    Comme A1 = ou on peu réglé (marche avant/frein et AV/AR …..
    1B = ? 1C = tension coupure des lipo et 1D protection de la température du vario et 1E protection de la température du moteur
    A + JPJ18
  6. #6
    Join Date
    May 2009
    Age
    31
    Posts
    234
    A votre avis est-ce qu'il convient pour le 1s ou non ?
    Car quand je regarde sur le site a priori il fonctionne pour le 1/12eme avec ou sans élévateur tel et la question ??
  7. #7
    Join Date
    Jan 2008
    Age
    44
    Posts
    125
    Salut a tous
    Le but de ma demande sur la traduction des tableaux, est de réalise un tableau pour les personne qui on du male avec l’anglai
    Donc si il y a des personne qui parle couramment l’anglai, sa serai GOOL de me donnée un petit coup de main.
    Donc si quelle qu’un peu me traduire de 2A a 5F merci
    Voici une photo du début du tableau :
    A+ JPJ18
  8. #8
    Faut mettre ton tableau Excel en ligne si tu veux qu'on puisse le remplir... Je veux bien essayer de te dégotter 5 minutes cet aprèm pour le faire...
    Chuis trop gentil...
  9. #9
    Join Date
    Jan 2008
    Age
    44
    Posts
    125
    Salut Airwave
    Je veux bien le mettre en ligne, mais je ne sais pas command faire
    Si tu me donne t’on e-mail en MP je te l’envoi
    Mon adresse est le jpmlc-jouffin@sfr.fr
    A+ JPJ18
  10. #10
    Join Date
    Nov 2005
    Age
    42
    Posts
    573
    2 : contrôle du taux de "punch"
    2a point de permutation du taux 1 au taux 2
    2b valeur du taux 1
    2c valeur du taux 2
    2d courbe de réponse des gaz, soit linéaire soit suivant une courbe fait sur pc
    3 : contrôle des freins
    3a frein moteur
    3b puissance total des freins
    3c frein initial
    3d point de permutation du taux 1 au taux 2
    3e valeur du taux 1
    3f valeur du taux 2
    3g courbe de réponse des gaz, soit linéaire soit suivant une courbe fait sur pc
    4 timing
    4a a 4e : boost
    4a boost maxi
    4b vitesse moteur de démarrage du boost
    4c vitesse moteur de fin de boost
    4d courbe de croissance du boost, soit linéaire soit suivant une courbe fait sur pc
    4e possibilité de lier ou non le boost a l'accélérateur
    5a à 5f turbo
    5a turbo maxi
    5b méthode d'activation du turbo via l'accélérateur, la vitesse moteur ou un mélange des 2
    5c délai d'activation du turbo
    5d vitesse moteur de démarrage du turbo
    5e courbe de croissance du turbo
    5f courbe de décroissance du turbo
    pour ceux qui on du mal a distinguer boost et turbo je peut faire un dessin
  11. #11
    Join Date
    Jan 2008
    Age
    44
    Posts
    125
    Salut mac gregor
    Merci pour ta traduction
    Pour résumé :
    « punch » puissance
    « boost » sur puissance
    « Turbo » sur sur puissance ??????
    Je ne voie pas très s bien la différance entre boost et turbo
    A+ JPJ18
  12. #12
    pour faire tres simple...
    punch: progressivité de l'accélération
    boost: ajout global de puissance (timing)
    turbo: ajout de puissance (timing) a haut regime
  13. #13
    Join Date
    Aug 2010
    Age
    30
    Posts
    19
    Et le deuxième tableau c'est les 10 profils enregistrés d'origine dans le vario
  14. #14
    Et ben sorry les gars, j'ai pas assez surveillé le topic...
    Mais au moins tu as tes réponses...
  15. #15
    Join Date
    Nov 2005
    Age
    42
    Posts
    573
    Quote Originally Posted by jpj18 View Post
    Salut mac gregor
    Pour résumé :
    « punch » puissance
    A+ JPJ18
    voila un graph que j'avait fait pour la precedente version de hw
    correspondance entre ancienne et nouvelle valeur
    9 = 4a
    10 = 5e
    12 = 5a
    13 = 4b
    14 = 5c
    15 = d(4a/(4c-4b))/dt (compliqué à expliquer)
  16. #16
    sa y est "mac" rentre dans des explications qui fait perdre c'est cheveux tellement le cervaux fume
  17. #17
    J'ai mal au crane... il m'a fallu 2 ans pour comprendre le sw precedent... Je garde mes V2.1...
  18. #18
    Join Date
    Aug 2008
    Age
    37
    Posts
    270
    Quote Originally Posted by Lonestar View Post
    Pas mieux !!!
  19. #19
    Join Date
    Jan 2008
    Age
    44
    Posts
    125
    Salut a tous
    Merci a tous pour la traduction et les explications.
    Voici une photo du tableau fini :
    Si il y a des personne qui désire le tableau au forma Excel, merci de me transmettre votre adresse e-mail en MP, où directement a mon adresse jpmlc-jouffin@sfr.fr
    Et si il y a une personne qui sais mettre un fichier Excel sur le cite.
    A+ JPJ18
  20. #20
    Bon ben maintenant que c'est fait le topic va se remplir de questions comme c'était le cas pour les v2.1... Aie aie aie...
    Qqn a une idée d'ou on peut le trouver? J'ai essayé de contacter M. Wartelle mais il n'a pas l'air de vouloir répondre...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. probleme Hobbywing Xerun 2.0 avec Speed Passion SP v3 6.5T
    By billybou in forum Système Brushless
    Last Post: 02-04-2012, 17:24
Liens sociaux
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
