Page 1 sur 3 123 DernièreDernière
Affichage des résultats 1 à 20 sur 46
Discussion: EFRA list Brushless 'Spec.' Motors
  1. #1
    Date d'inscription
    décembre 2006
    Messages
    16 025
    images
    5189
    Motors shown on this list are known to comply with EFRA 2011 Rules for Brushless 'Spec.' 10.5T Motors.
    This list is for reference only and should not be considered to be comprehensive. Products from other manufacturers may also comply with EFRA rules. Before using a motor not on this list, please bear in mind it is the competitors responsibility to ensure that any motor used complies with EFRA rules. It may be necessary to dismantle any unknown motor to check its legality, which is known to be a destructive process for most Brushless motors. Samples may be submitted for checking by EFRA officials before the event. If found to comply with the rules then they will be added to this list.
    Note: These motors differ from Brushless 'Modified' motors.
    MotorBuilder
    Type/Range
    Notes
    Date Checked
    Graupner
    GM Brushless PRO.Pt.# 973502011 version.
    Sensored system. "Y" Wind.Gun-Metal Aluminium End-Plates, GM-Racing etched.Gun-Metal stator sleeve with S10.5T & Pt.# etched.5 Timing threads. Side entry sensor plug. Black sintered rotor, 12.4 dia, 7.22 core.Rotor with one balancing ring. Bonded Sleeve.
    31.01.11
    Speed Passion
    3.0 - 10.5RPt.# SP1C105V31Cell
    Sensored system. "Y" Wind.Gun-Metal Aluminium End-Plates, SP & 10.5T etched. Gun-Metal stator sleeve with SP10.5T & 1Cell etched.Black sintered rotor 12.2 dia, 7.21 core.Rotor with one balancing ring. Adjustable timing. Bonded Sleeve
    31.01.11
    ORCA
    ORCA RX2Pt. #OBM105X2
    Sensored system. "Y" Wind.Gun-Metal Aluminium End-Plates, ORCA RX2 & 10.5T etched. Gun-Metal stator sleeve with ORCA RX2 & 10.5T etched. Black sintered rotor 12.2 dia, 7.22 core.Rotor with one balancing ring.Adjustable sensor plate timing. Bonded Sleeve
    31.01.11
    Trinity
    Trinity D3Pt. # TEP1050
    Sensored system. "Y" Wind.Gun-Metal Aluminium End-Plates, Trinity etched.Black stator sleeve with D3 & 10.5T etched.Nickel sintered rotor 12.3 dia, 7.22 core.Rotor with one balancing ring.Adjustable sensor plate timing. Bonded Sleeve
    31.01.11
    Dualsky
    Track & Field.Pt. # 53352
    Sensored system. "Y" Wind.Aluminium End-Plates plus Blue ring. Track & Field moulded on timing plate. Adjustable timing on sensor mounting. Stator sleeve with 10.5 etched. Nickel plated sintered rotor, 12.4 dia, 7.20 core with21mm Al. fan. Bonded Sleeve
    14.06.10
    Team Powers
    Team Powers Brushless 10.5 TurnsPt. # TPBLM 105100
    Sensored system. "Y" Wind.Black Aluminium End-Plates, Team Powers etched. 5 outer timing threads, 3 sensor mount threads. Black & Gold stator sleeves with 10.5T etched. Nickel plated sintered rotor, 12.3 dia, 7.22 core.No balancing rings. Bonded Sleeve
    12.04.10
    Graupner
    GM Brushless PRO.Pt.# 972902010 version.
    Sensored system. "Y" Wind.Gun-Metal Aluminium End-Plates, GM-Racing etched. 5 timing threads. Gun-Metal stator sleeve with S10.5T & Pt.# etched. Side entry sensor plug. Black sintered rotor, 12.3 dia, 7.22 core.Rotor with one balancing ring. Bonded Sleeve.
    28.01.10
    LRP
    X12 VectorStock Spec.Pt.# 50832
    Sensored system. "Y" Wind.Black moulded End-Bell with XTEC.Sleeve etched "10.5 Turns". Black Sintered rotor, 12.5 dia, 7.1 core. Rotor shaft, Black. Manufacturers 'grooved' Al. End-Bell withname engraved allowed at terminal end.Optional green rotor 50639 12.2, 7.1 core. Loose Housing
    23.11.0931.01.11
    Nosram
    Pure EvolutionSpec. RacingVersion.Pt.# 91831
    Sensored system. "Y" Wind.Black moulded End-Bell with XTEC.Sleeve etched "10.5 Turns". Black Sintered rotor, 12.5 dia, 7.1 core. Rotor shaft, Black. Manufacturers 'grooved' Al. End-Bell withname engraved allowed at terminal end.Optional green rotor 90639 12.2, 7.1 core. Loose Housing
    23.11.09 31.01.11
    Speed Passion
    3.0 - 10.5RPt.# SP138105V3
    Sensored system. "Y" Wind.Light Gun-Metal Aluminium End-Plates, SP & 10.5T etched. Light Gun-Metal stator sleeve with SP10.5T etched.Black sintered rotor with one balance ring, 12.3 dia, 7.22 core. Adjustable timing. Bonded Sleeve.
    05.10.09
    Novak
    BallisticPt. # 3610
    Sensored system. "Y" Wind.Black Al. End-Plate with NOVAK etched.Stator sleeve with 10.5T label. Stator removable.Nickel plated sintered rotor, 12.3 dia, 7.22 core. 3/16 Bearing at Pinion end.Blue plastic denoting 10.5. Adjustable timing.
    07.09.09
    Orion
    VORTEXRACE 10.5TPt.# ORI28133
    Sensored system. "Y" Wind.Black Centre Sleeve & End-Plates. Centre Sleeve loose.Orion logo and TOP etched on End-Plate but not 'wind'.10.5T etched on termination End-Casing.Nickel plated sintered rotor, 12.3 dia, 7.3 core.Rotor with 13.0 mm fan.
    05.02.09
    GM
    Sensored system. "Y" Wind.Dark Gun-Metal Aluminium End-Plates, GM-Racing etched.Dark Gun-Metal stator sleeve with S10.5T & Pt.# etched.Black sintered rotor, 12.3 dia, 7.22 core.Rotor with one balancing ring. Bonded Sleeve
    04.02.09
    SP
    WAVELinearPt.# TW2001-105
    Sensored system. "Y" Wind.Black Aluminium End-Plates with SP etched under label.Black stator sleeve with 10.5T etched.Black sintered rotor, 12.3 dia, 7.22 core.Rotor with one balancing ring. Bonded Sleeve.
    04.02.09
    Tekin
    TekinRedlinePt. # TT225310.5T Spec.(Can etched)
    Sensored system. "Y" Wind.Red Aluminium mounting plate. Black moulded End-Bell with Tekin.Grooved Al. bonded stator sleeve with 10.5T etched.Nickle plated sintered rotor, 12.5 dia, 7.26 core. No balancerings. Bonded Sleeve.
    15.12.08
    Speed Passion
    Speed Passion StockPt. # SPF105
    Sensored system. "Y" Wind.Black Aluminium End-Plates with SP 10.5T.Black stator sleeve with 10.5T engraved.Black sintered rotor, 12.3 dia, 7.25 core.Rotor with one balancing ring. Bonded Sleeve.
    08.09.08
    LRP
    Vector X11Stock Spec.Pt. # 50830
    Sensored system. "Y" Wind.Black moulded End-Bell with XTEC. Blue anodised ring. Chamfered mounting face. Sleeve etched "10.5 Turns".Sintered rotor, 12.3 dia, 7.35 core. Rotor shaft, Black.Manufacturers 'slotted' End Plates (std. & thin versions) allowed at pinion end.Manufacturers later 'grooved' Al. End Plate with nameengraved allowed at terminal end. Bonded Sleeve.
    09.06.08 19.07.08
    Novak
    SS Pro.Pt. #.3410
    Sensored system. "Y" Wind.Black moulded End-Bell with NOVAK. Blue plastic ring.Stator marked "10.5 Turns".Nickel Plt. Sintered rotor, 12.3 dia, 7.25 core.Rotor shaft with plain bevel at pinion end.Mounting face with or without chamfer. Loose Sleeve.
    14.04.08 28.04.08
    Nosram
    Spec.'StormEvolutionPt. # 91830
    Sensored system. "Y" Wind.Black moulded End-Bell with XTEC. Blue anodised ring.Chamfered mounting face. Sleeve etched "10.5 Turns".Sintered rotor, 12.3 dia, 7.35 core. Rotor shaft, Black.Manufacturers 'slotted' End Plates (std. & thin versions) allowed at pinion end.Manufacturers later 'grooved' Al. End Plate with nameengraved allowed at terminal end. Bonded Sleeve
    07.04.08 19.07.08.
    If an article is published in a language different from your mother tongue, make yourself sure you can understand the content!
    Si un article est publié dans une langue différente de votre langue maternelle, faites en sorte que vous puissiez comprendre le contenu par vous même!
  2. #2
    Smile Re : EFRA list Brushless 'Spec.' Motors
    cette liste n'est pas exhaustive ! retenez qu'elle est juste a titre d'indication et que d'autres moteurs répondant au SPEC EFRA sont les bienvenus .
    cordialement
  3. #3
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    Petite question justement à ce sujet.
    j'utilise un CS 10.5T avec rotor de 12.3 et pourtant il n'est dans aucune liste...
    Il est juste gravé "10.5T legal"
    Quelqu'un peut il m'éclairer ?
  4. #4
    Date d'inscription
    janvier 2002
    Messages
    11 401
    images
    29
    Pas pour france
    SELECT MODELS (SMS), MAGASIN de modélisme R/C en VPC, partenaire officiel de PETIT R/C
    Tél. : 04 78 64 06 20 N'hésitez pas à appeler pour renseignements, prix et commandes. Expédition le jour même (ouvert toute l'année). Si urgence : 06 09 97 45 12 Fax : 04 78 64 04 09 (24h/24)
    Tout en stock pour l'électrique, en Vente Par Correspondance 24H. Pour tous achats R/C, appelez nous : A votre service depuis 1992. Since 1992. Spécialiste électrique depuis 1980. Facilités de paiement (4 fois, sans frais). Cartes Bancaires, débit à expédition du matériel effectivement envoyé, vous ne payez jamais rien d'avance, contrairement aux sites en lignes. Arrivages quotidiens.
    Trinity • Orion • MIP • Novak • HPI • Schumacher • Corally • Proline • Yokomo • Protoform • Ride • Take Off • Paragon • PK • Race Tech • Race Craft • RW • Edge • TRC • LRP • Bud’s • Ellegi • Sanwa • Pete’s • Racer Choice • Thunder Design • CS • Hudy • Graupner • Select Models • Traxxas • Ballistic • M Troniks • Pactra • Infinity • Tekin • Ftw • Kimbro • Twister • Tamiya • Fastrax • Kawada • Kyosho • Cobra • GM • Badd Boyz • Factory Team • Frewer • Kose • PB • Pure Tech • Sanyo • Maxtec • Niftech • IRS • Carson • Robitronic • Pit Shimizu • Peak Perf • Reedy • Lunsford • Enetti • Médial Pro • Futaba • RPM • Nosram • Losi • KO • Asso • JC Racing • Echo • RCPS • Powers • JB • Panasonic • Fantom • TNT • SMC • TeamMagic • Keyence • Alclad • Hara • GP • Electronic Model • Sorex • 3 Racing • Spektrum • Grp • Tamiya • Roche • Bold • Cml • Wurtz • Speedmind • Atelsis • Eagle • Black art • CRC • Castle creation • Spintech • Teknipron • Atomic carbon • Laje • Intellect • IP • Fish • Rc edge • Titanium racing • Xenon • SIB • HB • East cost • Azarashi • Kanzen • JC concept • Spazstic • Matrix • Grepow • Xfactory • Speed passion • Advanced Core rc • Jaco • Checkpoint • Eds • Fastcolor • RC car • Rc edit • Rheinard • Moebers • DDP • Vampire • EnerG • Optimized • Kfactory • Xray • East Power • Vtech • Xceed • Factory parts • Deans • Sweep • Much more • Team bomber • BSR • Lipotec • M Racing • Spec R • Wrc • Parma • Kypom • Savox • Mobgums • MR33 • Mix • Prt • Moorespeed • GMK • RGP • Akula • Viper • D Boots • Fvss • Green rc • LMR • N Vision • Tought racing • Team powers • Pulse rc • Dprc • Durango • Napalm • BBR • R1wurks • T-works • Ghea • Gen Ace • RB • Answer • Orca • Espeed • Trickbits • Etronix • Thunderpower • Arrowmax • Serpent • Aka • VBC • Contact • Ame • Sticky Kicks • etc. (Tout ou partie de la gamme de ces marques). Stock permanent conséquent (Accus, moteurs, variateurs, chargeurs, kits, radio/servos, pièces, pneus, peintures, accessoires, carros, produits pneus, etc.); Conseils, compétence, sérieux. Prix internet! Spécialiste 1/12è, groupe C, DTM et TT, lipos et brushless. Adresse postale : Select Models bp9161 69263 Lyon cedex 09. Adresse magasin/accueil sur place : 78 rue St Pierre de Vaise 69009 LYON France
    Contact (courriel) : c.blandin@selectmodelsshop.com (n' utilisez surtout pas MP pour nous contacter, do not use PM, no mensaje privado por favor)
    www.selectmodelsshop.com
    www.selectmodels.fr
    (vente directe de quelques produits spécifiques, KANZEN par exemple, réglement en ligne)
    www.xfactory.fr
    www.azarashi.fr www.corally.com www.jaco-pneus.fr
    selectmodels.blogspot.com
    VOYEZ TOUTES NOS NEWS -->
    http://www.petitrc.com/_forumphp/forumdisplay.php?f=228
  5. #5
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    Pourquoi ??? par manque d'importateur ou pour vraiment une raison technique ?
  6. #6
    Date d'inscription
    janvier 2002
    Messages
    11 401
    images
    29
    J'importe Cs, mais il y a déjà plein de moteur sur la liste donc pas vraiment besoin d'un de plus
    www.selectmodels.fr
    www.xfactory.fr
  7. #7
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    bref..... Il répond aux normes donc je peux rouler avec ou pas ?
  8. #8
    Date d'inscription
    janvier 2002
    Messages
    11 401
    images
    29
    non
    www.selectmodels.fr
    www.xfactory.fr
  9. #9
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    Comment on fait pour le faire homologuer par la FVRC ?
  10. #10
    Date d'inscription
    janvier 2002
    Messages
    11 401
    images
    29
    Les importateurs le font chaque année aux dates idoines
    www.selectmodels.fr
    www.xfactory.fr
  11. #11
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    Donc vendant du CS je peux le faire ou il faut attendre 2012 ?
  12. #12
    Date d'inscription
    avril 2002
    Âge
    63
    Messages
    444
    images
    6
    "Comment on fait pour le faire homologuer par la FVRC ? "
    Tu en envois un exemplaire à la Fédé et s'il répond aux normes, il sera sur la liste; l'exemplaire que tu as envoyé est donc "sacrifié" !
    A l'époque, je l'avais fait pour des B&R 27trs et décalés à 44° !
    Donc, si t'en as qu'un exemplaire, ben après homolagation, t'en as plus !
  13. #13
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    un revendeur qui a qu'un exemplaire d'un moteur, c'est louche quand même...
  14. #14
    Date d'inscription
    avril 2002
    Âge
    63
    Messages
    444
    images
    6
    "un revendeur qui a qu'un exemplaire d'un moteur, c'est louche quand même... "
    Ta phrase me laisse perplexe !
    Tu es possesseur d'un moteur acheté apparemment hors du territoire national et qui est sur le catalogue d'un fabriquant "international".
    Pour des raisonss xx ce moteur n'a pas été importé et donc l'importateur ne l'a pas soumis à homologation.
    Donc, si tu veux qu'il soit homologué, tu peux le faire toi même en envoyant toi -même un exemplaire du moteur à la Fédé, sachant qu'il y a des dates et une période à respecter.
  15. #15
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    Etant importateur moi même (1/5) et faisant partie d'un club uniquement elec (Trets) c'est pas l'achat de 2/3 moteurs à 50€ qui vont m'arrêter...
    Maintenant j'attendrais les dates "officielles" pour faire homologuer ce moteur mais peut être sous le nom de ma boutique pour me protéger...
  16. #16
    Citation Envoyé par ycg Voir le message
    je vais essayer de répondre à tes questions simplement.
    il est gravé 10.5T légal car il répond au SPEC EFRA (bien que d'autre moteur aient le même gravage et qu'ils ne le sont pas).
    En France aujourd'hui ont utilise encore une liste d'homologation moteur (ce qui n'est pas le cas en EFRA) de manière a limité certain effet de course a l'armement et d'exclusivité .
    tu as donc une liste FVRC qui te dit quel moteur est autorisé en France.
    elle n'est pas discutable après sa date de parution (donc pas de nouveaux moteurs en cours d'année)
    en EFRA il y a une liste qui sert UNIQUEMENT d'aide au Contrôle technique mais qui n'est pas définitive. (donc n'importe quel moteur qui rentre dans les SPEC EFRA à légalement le droit de rouler en course dite "EFRA".Le pilote prend le risque de se faire démonter sont moteur pour un contrôle poussé).
    donc pour conclure:
    ton moteur est LEGAL EFRA tu peux faire un Euro avec si tu le souhaite
    mais il n'apparait pas dans la liste FVRC donc pas de CF avec .
    cordialement
  17. #17
    Date d'inscription
    décembre 2007
    Âge
    44
    Messages
    727
    Ok, merci de ta réponse.
    Cette année, je ne comptais pas faire de CF (ils tombent à la même date que les CF 1/5 qui restent ma priorité) mais peut être quelques ligues... On verra si quelqu'un me dit quelque chose .
  18. #18
    Date d'inscription
    juin 2010
    Messages
    762
    Et si un moteur est sur la liste efra mais ne figure pas dans la liste ffvrc ?
    Est ce que je peu utiliser mon trinity tep 1050 en cf ?
  19. #19
    Date d'inscription
    janvier 2002
    Messages
    11 401
    images
    29
    Si pas liste fvrc, non
    www.selectmodels.fr
    www.xfactory.fr
  20. #20
    Date d'inscription
    juillet 2007
    Âge
    19
    Messages
    403
    Je pensais qu'un moteur homologué EFRA étais forcement FVRC même si il n'étais pas dans la liste..
Informations de la discussion
Utilisateur(s) sur cette discussion
Il y a actuellement 1 utilisateur(s) naviguant sur cette discussion. (0 utilisateur(s) et 1 invité(s))
Discussions similaires
  1. Thunder Power RC Z3R 540 Sensored Brushless Motors
    Par Reporter dans le forum News / Nouveautés
    Réponses: 4
    Dernier message: 10/06/2012, 12h07
  2. Novak Kinetic
    Par S_Fender dans le forum Système Brushless
    Réponses: 68
    Dernier message: 20/04/2011, 12h09
  3. Tamiya Brushless Motors - Name Change
    Réponses: 0
    Dernier message: 13/01/2011, 12h44
  4. EPIC Dyno Tested Duo2 Brushless
    Réponses: 51
    Dernier message: 17/07/2009, 19h37
  5. Novak BL hors GTB et ses moteurs
    Par TKC dans le forum Système Brushless
    Réponses: 141
    Dernier message: 26/04/2008, 14h32
Règles de messages
  • Vous ne pouvez pas créer de nouvelles discussions
  • Vous ne pouvez pas envoyer des réponses
  • Vous ne pouvez pas envoyer des pièces jointes
  • Vous ne pouvez pas modifier vos messages
